View Full Version : My '67 Camaro goes back under the knife v. bc it's never done..
SIK02SS
09-09-2011, 02:02 PM
The car's been "finished" since 2005, but I was never very happy with how the engine bay turned out, so I decided it was time to make some changes while I had it at the shop to re-tune the carb and have the calipers sent back to Wilwood for a rebuild.
The shopping list:
Ron Davis radiator
SPAL 13" fans
Vintage Air Serpentine
AC evaporator
Master Cylinder
Headlights
Fuel distribution line to carburetor
Valve covers
Other to-do's:
Re-wire engine bay (new wire + hide wires)
Adjust and relocate choke cable
Upgrade headlight wiring
Re-plumb AC
Match all hoses and looms
Remove windshield washing fluid reservoir/lines/spray nozzles :lol:
Before:
https://static1.pt-content.com/images/pt/2007/09/DSC01738-1.jpg
https://static1.pt-content.com/images/pt/2011/09/DSC01760-1.jpg
https://static1.pt-content.com/images/pt/2007/09/DSC01741-1.jpg
https://static1.pt-content.com/images/pt/2007/09/DSC01734-1.jpg
https://static1.pt-content.com/images/pt/2011/09/45659649017843173784-1.jpg
https://static1.pt-content.com/images/pt/2011/09/23257308421268632119-1.jpg
Progress:
https://static1.pt-content.com/images/pt/2011/09/09663183173859607924-1.jpg
https://static1.pt-content.com/images/pt/2011/09/13342056209629900958-1.jpg
https://static1.pt-content.com/images/pt/2011/09/96115811288092735684-1.jpg
https://static1.pt-content.com/images/pt/2011/09/91551544975185506573-1.jpg
New master cylinder sans booster
https://static1.pt-content.com/images/pt/2011/09/00755521829419821668-1.jpg
New headlights and upgraded wiring
https://static1.pt-content.com/images/pt/2011/09/30907296506281857397-1.jpg
https://static1.pt-content.com/images/pt/2011/09/40427405181859497391-1.jpg
https://static1.pt-content.com/images/pt/2011/09/31226046481999172034-1.jpg
https://static1.pt-content.com/images/pt/2011/09/65836551306358682307-1.jpg
Once this project is done, next up is selling the wheels/tires and getting some 18s put on :cheers:
Eric Howell
09-09-2011, 02:19 PM
Very nice! Look forward to updates. Any chance you know the color code for that blue? I have been looking for the perfect blue forever...
SIK02SS
09-09-2011, 02:26 PM
Thanks! It's electron blue found on some of the C5 Corvettes..only I think the painter didn't prep the color correctly. I think black was supposed to be an under-coat to the blue (to get the same color as GM), but he didn't do that so it came out lighter than it was supposed to..which I actually like more :)
Eric Howell
09-09-2011, 03:14 PM
I typed out so much then the computer restarted for update.. Thank you for the info. I have been told black under silver and dark blue. Lighter blues, grey or silver. Thanks. I have an idea now.
Honestly, I'm not a 1st gen fan much but the 1st and 3rd pics you posted, I might change my mind :1st::yum:
Vicinity
09-09-2011, 03:45 PM
You got one nice looking car. Details on the headlights?
SIK02SS
09-09-2011, 05:10 PM
:lol: thanks!!
Thank you! You're the 2nd person in the last couple days who's asked...let me do some digging, I bought them a few months ago and sat on them for a while. Only modification to make them fit is cutting out the round "bowl" bracket it sits back into with a slightly larger diameter circle then stock. These were cheap too IIRC
SIK02SS
09-26-2011, 09:02 AM
Couldn't find any info on the headlights....essentially they are the Autolock snake eyes headlight, but i removed the snake eye (was held in with a screw)
More pics:
https://static1.pt-content.com/images/pt/2011/09/16441248311868670927-1.jpg
https://static1.pt-content.com/images/pt/2011/09/15964262689150161642-1.jpg
https://static1.pt-content.com/images/pt/2011/09/13922902205941868767-1.jpg
https://static1.pt-content.com/images/pt/2011/09/70098838945586203552-1.jpg
the new front main seal is leaking again already, so it must've gotten cut installing..still need a new air cleaner to get rid of the billet specialties piece that doesn't fit in anymore, need a new valve cover breather bc i have a mr. gasket piece for temp use right now :badteeth:, and need a thermostat bc the shop couldn't find one to work .....but over all I'm pretty happy with how it came out. They even adjusted some body gaps. The car is much more of a pleasure to drive now too :yup:
oh, and i need to take that insulation piece off the AC box and put some of the adhesive 'foil' type on instead that you find on racecars
went from this:
to this:
Chris 68
10-27-2011, 05:50 PM
Wow you really transformed that engine bay, very clean camaro! :twothumbs How do you like that wilwood master?
Rod
10-27-2011, 06:24 PM
looking good so far!!!
SRD art
10-27-2011, 11:08 PM
Yep now the engine bay is catching up the the rest of a gorgeous car! Keep it coming!
