View Full Version : engine start button, can't find the wire to use to wire it up
Hotwhilz
09-08-2011, 10:40 AM
Hello Guys, maybe someone can shime in and point me in the right direction, here is the deal:
The instruction for this universal start button tells me to find the two wires that connect to the silenoid, do you guys know where I can find them on the car ?
The wiring harnees from the column goes to two different relays look alike are those for the starter?
I looked inthe haynes manual but they only point out a yellow wire!
Please any help would be appreciated.
Thanks in advance
Ben
John Wright
09-08-2011, 10:43 AM
How many terminals does this start button have? I ask because you didn't say whether it is just a starter switch or if it has an ignition postion also.
Hotwhilz
09-08-2011, 01:31 PM
Sorry, it would have helped a bit!
It a starter button only, the push button got to prongs one for 12V ignition power the other back to a 4 prong relay,
Out of the relay, one ground, the other for 12v and the other two big wires to the supposed to be 2 wires for starter?
Hope it is clear enough for your understanding?
