View Full Version : sea foam with carb
Hunter68
09-01-2011, 10:57 AM
I really want to try this and see how it works but i wasnt sure on exactly how to do it, do you just go ahead and put it through the vacuum line to the brake booster or just put a little in to the carb its self?
anthonys 69
11-09-2011, 10:48 PM
To de-carbon a motor with the engine running you can feed a very small amount at a time through the smallest vacuum hose you can find. Not through the brake booster hose if you but to much fluid to fast it can cause engine damage. Sea foam is a great fuel treatment I use it on my boat lawn mower and from time to time my vehicles. I just add it to the fuel if you have fuel problems say from sitting for a long time you’ll need to clean the carb but sea foam is great to protect your fuel system
Hunter68
11-10-2011, 09:43 AM
im just to afraid to run through he gas and be smoking for a week ha
anthonys 69
11-10-2011, 04:53 PM
Sea foam wont make it smoke. But if you just want to run some cleaner through your system id just fill up with chevron gas it already has a good cleaner in the fuel
