View Full Version : Opel Manta A 3700 -71
MikkoV
08-16-2011, 11:25 AM
Though i could post thread from my first retroproject, after seeing that one Volvo project here.
I bought this old Manta in 2001 and spend few years playing with it and building it then. I still have it and propably never going to get rid of it.
Could be time to little take it to this decade (/or millenium) at some point and redo some stuff, but this is how itīs now...
Specs:
Engine:
307hp / 420nm
-28S Engine block
-Wösnerr pistons
-Connection rods and crankshaft from 3.6 litre C36NE Irmcher engine, C30NE cylinder head, lowered and ported flowing aprx 350hp, compression ratio 12:1
-Cat Cams camshaft, 320deg 12.5mm
-3x Dellorto DHLA 45 carburators
-Custom aluminiun oilpan
-Light flywheel
-Irmscher oilcooler
-Custom radiator
-Crane HI-6 Ignition with LX-92 coil
-Custom headers and 2x 2.5” exhaust
Transmission:
-9" BMWīs SRE Racing clutch with copper plate
-Getraq 265 5-speed gearbox from Opel Monza GSE
-Itīs own rear axle, 3.67 LSD 40% differential, with Steel driveshafts
Suspension and chassis:
-MAD lowering springs -40mm
-Bilstein shock-absorbers in front
-GAZ adjustable in rear.
-22mm rear stabilizer
-Fast steering
-Rear axle has watt-link and bushings have replased with unibalīs
-Polyurethane bushings at front
-Front brakes are 296mm zimmermann discs (vented and drilled) with Brembo calibers
-Rear brakes are Calibras zimmermann drilled discs with Astra turbos brake calibers, EBC pads in both, linelock and pressure regulator.
-Full rollcage
-Schmidt 8 x 15 rims with 205/50R15 tyres
Bodywork:
-Resprayed with GT/E theme
-GT/E frontspoiler
-all factory weldnings seam-welded
-Everything at chassis sprayed with black urethane paint and axles etc. with grey
Interior:
-Cobra bucket seats
-Autogauge rev- oilpressure, water temp- and fuel mixture meters
-6-point rollcage
Other:
-Best 1/4 mile 12.88s - 178km/h.
And here some more pics, misc.
In use, few years back...
And one old videoclip, from early Finnish "drift competitions" and tracksdays...
http://www.youtube.com/watch?v=ZMZmb7h0DP8
wellis77
08-16-2011, 11:36 AM
I LOVE IT!!! My next build is a 1974 Manta that will be built as a racer inspired by WRC. Great looking ride!
79-TA
08-16-2011, 11:39 AM
That's a great looking little car. It looks even better in motion.
yodas little brother
08-16-2011, 12:46 PM
you always have some good vids
Mr. Anderson
08-16-2011, 01:30 PM
How cool is that!!! Love the car Mikko.
cobragt
08-16-2011, 06:21 PM
Very cool!
grenade inspector
08-16-2011, 06:27 PM
very cool manta, I like the watts setup
