JonRB
08-14-2011, 04:52 PM
:hammer:I'm getting close to starting on the cage for my 2nd gen Firebird. The hard parts;
I'm probably within a week of finishing my tube bender, which should bend 1&3/4 up to 120degree with the potential to bend more degree with new dye$. And I have a 200amp tig machine. I've welded roll bar kits in cars before, even with subframe connectors seam welded with out riggers to the cage. I had to build my own tube bender cause I want this cage tight to the roof, and A-pillars, through the dash, and I couldn't afford to buy a bender. And my cage has to be tight to the roof - like perfect.
Now here's what I want; I want the whole thing tube framed, pretty much. I want bars from the front, (somewhere between the A arms and the radiator) to the back (in the trunk); my front end is all glass with no inner fenders. I want working wipers and the option for an engine set back alittle. The car is a Doug Nash 5-speed Pontiac V8 and I want it to remain street legal.
Here's my problem(s). I plan on going with 1&3/4. And I may swap the rear suspension in the future. As you know, the factory has half a frame in the front, nothing in the middle(theres CE bolt in connectors in there now), and rear frame rails made of basically stamped sheet metal. It just doesn't seem right to me to weld a good quality cage to stamped sheet metal in the back. Even the CE weld in rear rails are only .083 mild or something, but they wouldn't work for a future rear suspension swap anyway. I know the back of the car is light, and doesn't need to support the weight that the front does. But really, a 120 wall hoop to a 120 plate welded to a stamped sheetmetal floor doesn't seem right to me. I know it's legal for alot of racing classes, but I just don't really want it done that way.
So for the middle section of the floor, should I weld in connectors made of 120 with provisions for cage mounts and start there? Or should I go about it another way? I don't want to chop out the whole floor and weld the body on the new frame(tube drag style), cause I want it to keep some of it's original charicter. Ideas? Where should I run the rails?; in the stock places or should I lop the back of the subframe and move the rails out board to the rocker? Maybe four rails from the front to the back?
And now the really hard part. The rear. Right now it's on landrum race springs with konis in the original salisbury/leaf suspension. I'd kind of like to just leave that for the time being untill I sort out my future rear suspension, Which I've been collecting ford SVT 8.8 termminator parts for, but I havent made the subframe, Dual A arms, nor sorted out any of the geometry for that yet, and that may take years. I just have the aluminum center, halfs, and dual A knuckles as of yet (I plan on going full spherical and no subframe isolation for the irs). So should I just run the bars that come down from the cage and harness bar down to the original floor in the back, and expect to dang near back half all of that in the future? Or should I do somthing now, preparing for enough room for the irs whil reataining mounts for the leafs so the car isn't sitting with out an axle for possibly years and I could move it around, even drive it?
I started going with the irs cause I want rear tow and camber. And the irs seemed to make more sense than a floater axle.
Thoughts, words of caution, suggestions, ideas. I need as every thought, idea, and knowledge you guys could offer.
What about fixtures? Super serious, or I have a brain and I could get this straight with out one? I think I could get it straight, I think fixtures would make it easier, but consume more time and materials in making them for a one-off car.
