View Full Version : 4th gen, strange clutch problem
06-25-2005, 07:13 PM
Just recently Gina noticed the clutch pedal feels soft and at times it sticks a quarter stroke down. She can pop it back up with her foot.
The clutch feels fine so I suspect the master is going or it took in some air. The slave looks dry, I had it up and used my fiberoptic scope to check it. No abnormal slack... wondering if any of you guys had this problem. TIA
gEtyOpAPiOn
06-25-2005, 08:34 PM
i know 98-00 had the problematic throw out bearing ...what year is yours ? i know you can mod the cylinder too
rocketman
06-25-2005, 09:19 PM
the lt-1s are known for junk s/c,that would be my guess 1st.a new gm is the best bet.
06-25-2005, 09:49 PM
Sorry its a 2000.
zbugger
06-25-2005, 09:51 PM
I'm thinking it's the throwout bearing too. Especially being that she can kick it back out.
gEtyOpAPiOn
06-25-2005, 10:58 PM
good thing is that those t 56s are so easy to work on
06-25-2005, 11:22 PM
Thanks guys, looks like it will get rack time in August. Them T56's sure beat the 45RFE's!
SatisTraction
06-26-2005, 05:32 AM
I have heard of several problems that cause this. one is that the supply line is to close to the exhaust. several of my drag budies have had to move and insulate the line. Then there is the drill mod. i would try those before i pulled the tranny.
Wildron
06-26-2005, 07:29 PM
very common problem with the lsx trannys.just change the throw out.problem solved.been thru this more than once.the drill mod is a MUST do thats for sure
06-26-2005, 08:56 PM
Thanks for the info guys...would someone be kind enough to explain the drill mod to me? To lazy to search LS1.
zbugger
06-26-2005, 09:56 PM
I can explain it to you tomorrow at your shop when I get there.
06-26-2005, 10:19 PM
got it, thanks for the PM and link Steve...here it is for everyone eles
http://www.installuniversity.com/install_university/installu_pages/sophomore_year/drill_master_cylinder.htm
