View Full Version : All BRP/Musclerods Items on Sale!!! LSx and 5.0 swap kits, Brake conversions, etc!
BulldawgMusclecars
08-10-2011, 10:56 AM
Engine Swap Kits
1967-1969 F Body, 1968-1974 X Body $429.00
1964-1972 A Body 439.00
1973-1977 A Body 439.00
1978-1988 G Body 439.00
1962-1967 X Body 429.00
1963-1982 Corvette 429.00
1970-1981 F Body 429.00
1982-1992 F Body 439.00
1955-1957 Chevy Passenger Car 449.00
1958-1964 B Body 429.00
1991-1996 B Body 439.00
1982-1993 S10 2WD (not Blazer) 439.00
1982-2000 S10 4WD 259.00
1994-2003 S10 2WD Pickup and Blazer 439.00
1967-1972 GM Trucks 429.00
1973-1987 GM Trucks 429.00
1988-1998 GM Trucks 439.00
1982-1993 Mustang 449.00
1982-1993 Mustang Coyote 5.0 449.00
1975-1978 Datsun 280Z 459.00
Headers- CALL or email, we can beat ANYONE's price on BRP Musclerods/Hedman headers!
1967-1969 F-Body/1968-1974 X Body Rear Shock relocation Kit $249.00
13" Brake Kit for 4th Gen F Body (must use 98-02 spindles) $799.00
13" Brake Kit for early GM short/2 piece spindle (A,F,X), uses modified drum brake style hubs
w/hubs $899.00
w/o hubs 799.00
($40 core charge on hubs)
12" Brake Kit for early GM short/2 piece spindle, uses 1998-2002 F-Body components and modified drum brake style hubs
Front brackets, spacers, and hardware only for drum or disc spindles (specify which) $139.00
Above, with machined hubs 289.00
Adapter plates for using 1998-2002 F-Body rear discs on early 10/12 bolt $39.00
For all orders please specify make, model, and what transmission you plan to use! We install what we sell, and are a full service restoration/performance shop. Thanks!
John Wright
08-10-2011, 11:00 AM
What items come in the engine swap kits?...ie 70-81 Camaro LSx swap
Z06vet
08-10-2011, 11:40 AM
Same as above for 1st gen f-body.
BulldawgMusclecars
08-10-2011, 01:30 PM
The swap kits come with the trans crossmember for your choice of transmission (T56, 4L60E, 4L80E, etc), the block side mounts, frame mounts, and all Grade 8 hardware for the installation. All the steel pieces are powder coated silver (looks similar to ceramic coating), and the urethane insulators (for the engine mounts and the trans mount) are Energy Suspension, with a lifetime warranty. You have a choice of red or black for the urethane. The mounts bolt up easily in existing holes in your frame. The biggest advantage to these kits, other than not having to worry about clearance issues with the tie rods to oil pan, coil packs to the heater box, or driveline vibrations is that they are engineered to work specifically with Hedman's headers. For most applications, we offer shorties, mid lengths, and full lengths, in a variety of sizes. Best of all its all USA made, right here in Georgia.
If needed, I can also offer some of the needed/desired items to complete the swaps...affordable custom built radiators, Cable-X boxes, performance parts, etc.
t72ss402
08-10-2011, 04:36 PM
Do you have the kit for 78-81 G-body? I am in the market for one for my 79 Malibu.
Thanks Tim.
Z06vet
08-10-2011, 07:50 PM
So its $429 for just the crossmember, bolts, & motor mounts? How much are headers, what brand are they, and what oil pan is required? I used a BMR crossmember in my 69 and is was $180. Are the mounts & stands that much? Scott
BulldawgMusclecars
08-11-2011, 06:36 AM
Thanks Tim.
We do.
BulldawgMusclecars
08-11-2011, 08:32 AM
It may seem a little high at first, but this isn't some semi-universal plate kit. This is a fully engineered system for each specific model, that eliminates all the swap headaches...what headers will fit, oil pan to tie rod clearance, bellhousing bolt access, valve covers/coil packs hitting heater boxes, etc. If you add up the cost of a crossmember ($180), plus a set of plates ($80), frame mounts and trans mount ($90), and throw in the cost of powdercoating the mounts and the hardware, plus the shipping or time to track down all the parts you haven't really saved anything...comparing apples to apples. Every swap kit that BRP/Musclerods designs (on an actual, full optioned car) then goes to Hedman Headers to have not one, but several different types of headers designed specifically around it. That alone is worth the price to me. You don't have to rely on internet hearsay, or cut up a set of existing headers, or sacrifice clearance just to get a header on your car. You don't have to settle for 1 or 2 different headers, either...for most applications they have several. For first gen Camaros, they offer:
1 3/4" mid lengths $479
1 3/4" long tubes $639
1 3/4" to 1 7/8 " stepped long tubes $689
1 7/8" long tubes $659
1 7/8" to 2" stepped long tubes $789
2" long tubes $689
These prices are only through Bulldawg Musclecars to Pro Touring members, and reflect a substantial savings.
These aren't cheap Chinese headers either... they are 100% USA made by Hedman's Husler Racing Division, and have the thick flanges and quality construction you would expect. They come coated with Performance Coatings' ceramic coating, also, which is the highest quality you can buy.
Oil pan requirements vary according to the kit, but most (including this application) can use the GMPP Musclecar pan.
BulldawgMusclecars
08-11-2011, 11:47 AM
Thanks Tim.
I just realized that I hadn't posted those years; its a different kit than the 82-up, but I inadvertantly left it off. Its $439.
t72ss402
08-14-2011, 04:48 AM
How long are you going to be at these prices?
BulldawgMusclecars
08-14-2011, 08:31 AM
As long as possible, but since I am not the manufacturer I have no control over any cost increases on the manufacturer end. I don't plan to raise my prices unless my cost increases.
DarkoNova
08-14-2011, 10:03 AM
Details on the rear shock relocation kit for a 69 Nova? What's included?
t72ss402
08-15-2011, 05:04 PM
Sent you a P.M. I am wanting to place an order for this kit.
BulldawgMusclecars
08-16-2011, 10:16 AM
Sorry I missed your post! The kit includes the upper shock crossmember, lower spring plates, hardware, and detailed instructions. Its especially helpful for minitubbed vehicles. The lower spring plates have built in mounts for parking brake cables that can be used for most rear disc conversions, including the '98-02 F-body style that the housing brackets are sold for.
BulldawgMusclecars
08-16-2011, 10:17 AM
Thanks for the order!
Later-A-body
09-07-2011, 10:33 PM
I will be calling you to place an order for the '73-'77 GM A-body kit. I already have a trans crossmember, but will need the motor mounts and full length headers.
BulldawgMusclecars
09-08-2011, 07:17 AM
I can probably get them to break up the kit, but keep in mind that the geometry/mounting of the crossmember you have may be different. You'd probably be better off selling your existing one to someone else.
BulldawgMusclecars
03-03-2012, 09:52 AM
These prices are still in effect, BTW...BRP hasn't gone up so far, and neither have I.
Project Cortez
04-16-2014, 04:07 PM
I know it has been a while any sales on the BRP LSX kits???
BulldawgMusclecars
04-17-2014, 06:26 PM
Call me tomorrow- 770-570-7960. I'll see what I can do.
kirt70camaro
04-19-2014, 03:26 AM
Upper and lower control arms for 67 camaro.
zamora7
04-21-2014, 09:49 PM
Do you still offer the brackets to use ls1 fbody brakes for raw the ten bolt cars, I want fast disk breaks in a 81 bird.
