ModernMuseum
08-10-2011, 06:23 AM
1. I am looking at the following connection for the PCV system (passenger side of throttle body).
https://static1.pt-content.com/images/pt/2011/08/6016275772_5854b8dcdc_z-1.jpg
I have this little plastic line that I believe is supposed to connect it to a port right below itself on the intake: http://farm7.static.flickr.com/6147/6020415230_e1dff15995_z.jpg
However, unlike this photo that I found on ls1tech (which I believe is an LS3),
https://static1.pt-content.com/images/pt/2011/08/DSC07544-1.jpg
the plate under the intake on my engine doesn't appear to have that connection. Any advice how I should hook this up? My engine is an L76 with an LS3 top end (in case that makes a difference). How or where should I connect this to if I don't have the same connection below the intake?
2. Do I need this Evap Emission Purge Solenoid for the engine to function correctly? If so, where does it connect to (pic taken from another, I believe, LS3 engine)?
http://i70.photobucket.com/albums/i98/mcmlxix/LS3/DSC07534.jpg
3. This port is capped at the back of my driver's side valve cover
https://static1.pt-content.com/images/pt/2011/08/DSC07532-1.jpg
Do I need to connect it somewhere?
4. How about this connection on the driver's side of the throttle body?
https://static1.pt-content.com/images/pt/2011/08/6015723559_2971534341_z-1.jpg
5. I plan to connect this red capped port (passenger side of intake) to a barbed bung in my 4" air intake, between the MAF and the throttle body. Is that correct?
6. My harness has a connection titled "VEH SPD" which I assume connects to the VSS sensor on my T-56 Magnum. Any comments on how to get this to talk nice with my Dakota Digital gauges?
