View Full Version : 69 camaro control arms: too many choices!
Joker69Camaro
08-09-2011, 06:17 AM
Ok I think I have completely overloaded myself with information trying to figure out what control arms to purchase for my car.
Right now I have rebuilt the lowers with the Global West Del-a-lum bushings and the uppers with moog to get it on the street about a year ago. The rear suspension is done (BMR Watts link) and time to do the front so I can get this thing back on the ground after 6 months. I don't mind replacing both arms if necessary but all ready invested coin in the lowers, but im sure I could sell em.
Im looking for some input from people who have used different control arms on their car, thoughts, experiences.
Another thing, do all of these clear once the G-mod is done without cutting down the old mounting point?
ProdigyCustoms
08-09-2011, 01:00 PM
Only Speedtech and Ride Tech Arms work with the redrill.
MyFriendScott
08-09-2011, 04:36 PM
I was overwhelmed too on the choices so I started looking into the claims made by each manufacturer and trying to separate the wheat from the chaff. Maybe you might find something from this discussion too.
https://www.pro-touring.com/showthread.php?80648-Aftermarket-First-gen-F-Body-A-arm-Geometries&highlight=
clancj
08-09-2011, 07:47 PM
my cpp's dropped right in after g-mod re-drill without interference.
Rod
08-09-2011, 09:53 PM
elaborate please,,, ?
Joker69Camaro
08-10-2011, 05:04 AM
I started the phone call dance yesterday. Pretty sure I found my answers. Thanks folks! This, I think, was my last major decision to make on the car!
Thanks Frank. That was one of the major questions I couldn't get answered from anyone. Also If after I re-drilled if there was clearance so i didn't have to cut down the mount. (in case i ever wanted to go back to stock)
BMR Tech
08-15-2011, 01:33 PM
I would use a tall upper ball joint before I would do the G-mod. The G-mod is free but the tall ball joint is simpler, more beneficial and still very reasonable. We recently mapped the camber curve of the G-mod vs. tall ball joint vs. tall spindle and the tall ball joint actually gives a little better camber curve than the G-mod does, about .2-.3 degrees more negative camber per 1/2" of compression.
GaRys69
08-15-2011, 05:54 PM
So how does the tall ball joint compare to the tall spindle? AFX spindle?
BMR Tech
08-18-2011, 01:29 PM
Our test assumed a 25" tall tire with a 6" frame height. The tall ball joint was tested against an AFX spindle and the camber curve remained similar until the bump reached 1.5" from static. At that point the curve became a little more aggressive, gaining -.3 at 1.5" compression, -.4 at 2", -.5 at 2.5", and -.6 at 3" over the tall ball joint. These numbers are better and the spindle would be the ideal choice however the value of the tall ball joints cannot be discounted. Generally speaking I would say that for the average enthusiast, tall ball joints will improve the camber curve sufficiently for most driving requirements...
Jesse72
08-19-2011, 01:16 AM
BMR, thanks for the input! Not trying to steal the thread, just thought this would be helpful to others too)
*That makes things a little easier for us guys that cant spend 1000+ dollers on spindles alone! Allthough everyone would love AFX and Corvett brakes its a little unobtainable for the average enthusiest! This is great info. Would you recomment a set up like this for a car that only sees the track every once and a while?:
-SPC Adjustable uppers
-tall upper ball joints
-stock spindles
-2" drop springs or coil overs?
-Sotck or aftermarked lower control arms? Maybe BMR's since they accept both coil spring and coil overs?
Thanks alot, the wife makes me a budget guy! Hahaha
BMR Tech
08-22-2011, 05:39 AM
That setup will definitely wake your car up. A better camber curve, increased positive caster capability, and a lowered CG is what we are all looking for. Your build recipe will accomplish all of that and at minimal cost. Nothing wrong with that! We are actually in the process of re-designing our first gen A-arms. I am not sure when you will be ready but in a week or two our A-arms will have increased positive caster and require less shim stack to achieve proper camber settings on lowered vehicles. We are adding 2 degrees of caster to the lower A-arm and 2 degrees on the upper. This split keeps the wheel centered in the wheelwell and allows plenty of positive caster without a lot of staggered shims.
Jesse72
08-23-2011, 03:57 AM
Thanks for the advice BMR. I plan on this setup soon as I can start wrenching again!
Spitfire44
08-23-2011, 11:50 AM
Can someone provide a link to the tall ball joint? Thanks in advance.
BMR Sales
09-08-2011, 01:52 PM
We do not have the tall ball joints on the website yet, but we will have them and some other 1st gen front end goodies...
Joker69Camaro
09-09-2011, 09:38 AM
Waiting Rich. It was nice talking to you the other day up at the shop.
DEIGuy38
09-09-2011, 07:35 PM
Howe Racing Ent is another company that has tall upper ball joints and taller outer tie rods for adjusting bump steer
http://www.howeracing.com/c-560-howe-precision-ball-joints.aspx
BMR Sales
09-12-2011, 06:48 AM
Hey Jeff! We are working on the front end goodies.... remember....... "good things come to those who wait".
BMR Sales
03-28-2012, 07:31 AM
Hey Jeff....:secret:
https://static1.pt-content.com/images/pt/2012/03/IMG_20120328_102507-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_20120328_112035-1.jpg
New A-Arms are also on the way.......
Joker69Camaro
03-29-2012, 05:12 AM
57456
chevelletiger
03-29-2012, 06:30 AM
I really hope you guys do this for us abody guys we need it,speedtech said there a yr away from even thinking of getting to it i need it soon!phil
BMR Sales
03-29-2012, 07:16 AM
I really hope you guys do this for us abody guys we need it, speedtech said there a yr away from even thinking of getting to it i need it soon!phil
You mean like this.......:bananna2:
https://static1.pt-content.com/images/pt/2012/03/ABodyCoiloverConv12-1.jpg
killer69
03-29-2012, 07:19 AM
Speedtech has looked at doing a "Chicane" upper coil over mount on the A Bodies as well as G Bodies. and will have something in the near future
BMR Sales
03-29-2012, 09:51 AM
We will have the A-Body Coil Over kit with our new design caster correct A-Arms as well as our 1st gen F-Body Coil Over kit & caster correct A-Arms on display this show season.:twothumbs
BMR Sales
03-30-2012, 06:07 AM
By popular demand.......... here you go guys! a sneek peek at our new caster correct A-Arms with new ball joint cup & bumpstop brace design::smoke:
https://static1.pt-content.com/images/pt/2012/03/IMG_20120329_145611-1.jpg
regal454
04-02-2012, 07:06 AM
Rich,
When will these redesigned 1st gen control arms be available?
BMR Sales
04-02-2012, 08:32 AM
They will be available to ship by the end of this month.
https://static1.pt-content.com/images/pt/2012/04/IMG_20120329_144448-1.jpg
We can place them on order for anyone interested in getting the first batch. We do not charge the card until the parts ship.
efs69
04-05-2012, 04:46 PM
These are nice! What type of bushings are you using? Do these change the ride height?
BMR Sales
05-14-2012, 12:59 PM
Poly bushings and our lower arms do not have lowered spring buckets. Here is a picture of our rolling suspension for the 1st gens...which has our new front control arms, coilover kit installed.
https://static1.pt-content.com/images/pt/2012/04/IMG_20120413_124554-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_20120403_173811-1.jpg
Joker69Camaro
05-15-2012, 05:22 AM
Hmm I may have to swing by to take a "look" at these new toys
:seizure:
BMR Sales
05-15-2012, 07:48 AM
Jeff,
Definitely, when you come to the shop I need to show you a set of these too::bananna2::twothumbs:headbang:
https://static1.pt-content.com/images/pt/2012/05/SFC006_large-1.jpg
Joker69Camaro
05-15-2012, 02:25 PM
Yes, im pretty sure we can just wrap those up to go. I am going to need the clearance over my current weld-ins for the exhaust.
Or do you mean the stickers? Cause I don't have any of those either :)
BMR Sales
05-16-2012, 01:15 PM
Jeff,
Here are a few pics of them installed in our 69 project car...
https://static1.pt-content.com/images/pt/2012/05/IMG_8662-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_8625-1.jpg
