View Full Version : converting a Chrysler 383 to LS fuel injection
Chadly B
07-30-2011, 07:19 AM
like the title says, I'm planning on using an ls fuel injection system on my 383, and I think I have everything figured out with the exception of the cam and crank sensor signal, I can't be the first guy that's done or attempted this, but suggestions would be great....
EFI69Cam
07-30-2011, 03:48 PM
Check out this website. www.eficonnection.com you might get some ideas there.
I've converted a BBC to LS control, but there are factory parts to do that.
TT302Z28
07-30-2011, 05:07 PM
The main issue become crank position sensor. Not sure how you would get a reluctor to work.
andrewb70
08-08-2011, 05:23 AM
Externally mounted to the balancer.
Chadly B
08-13-2011, 08:32 AM
that's what i figured on the crank, thanks Andrew...being a bit (A LOT) green on efi, I've been told just put a hall effect sensor in the distributor, I don't think that's much of an undertaking, I don't have a distributor yet, so I'm going to look in to some options.....
