View Full Version : 1969 camaro hood hinge
circle
07-26-2011, 01:30 PM
What is the correct color for hood hinges on the Camaro, is there a paint available for correct color and finish
MuscleRodz
07-26-2011, 01:34 PM
phoshate coated is correct finish. kinda dark flat gray.
redfire69
07-27-2011, 04:51 AM
Try this: http://www.eastwood.com/ew-zinc-phosphate-aerosol-12-oz.html
circle
07-30-2011, 11:09 AM
Thanks, is the spring black, or same color as the hinge.
Also do you know what is the correct color for the valve covers, 69Z
MuscleRodz
08-01-2011, 06:54 AM
Also do you know what is the correct color for the valve covers, 69Zsame color as hinge. these questions will be better answered over at camaros.net. better yet, do a search over there and you will probably find an answer for all your correct finish questions
TT302Z28
08-01-2011, 10:25 AM
There are also Camaro Restoration books that have the down to nut and bolt detail. Sounds like you are performing as true restoration, one of these books would be a great resource for you.
