ChevelleNV
07-22-2011, 10:44 AM
Summit Racing SUM-770322 - Summit Racing® Transmission Crossmembers
Has a few scratches, but like new never used
Retails for 260.00 asking 150.00 + SHIPPING you save over 100.00
73-77 GM A-Body
PONTIAC GRAND LEMANS, LEMANS, GRAND PRIX, GRAND AM, GTO
CHEVROLET EL CAMINO, MALIBU, LAGUNA, MONTE CARLO, CHEVELLE
BUICK CENTURY, SKYLARK, REGAL
OLDSMOBILE CUTLASS, CUTLASS SUPREME, VISTA CRUISER
http://www.crossmembers.com/shop/product_info.php?cPath=18_21_23&products_id=69
FITS THE FOLLOWING TRANSMISSIONS: TH350, MUNCIE, POWERGLIDE, T-10, TH400, 2004R, SUPER T-10, SAGINAW, TH200 FINISHED IN A BLACK POWDER COAT. INCLUDES NEW MOUNTING HARDWARE. PURCHASE TRANSMISSION MOUNT SEPERATELY. P/N GMTM.
1973-1977, HARDTOPS ( NOTE: DISTANCE BETWEEN CROSSMEMBER FRAME HOLES IS APPROXIMATELY 51-1/8". MEASURE YOUR FRAME OR CROSSMEMBER TO INSURE PROPER SELECTION) NOTE: WILL NOT FIT 73-75 EL CAMINOS WITH THE BOXED FRAME RAILS.
# INSTALLATION NOTES: THIS CROSSMEMBER IS INSTALLED WITH THE G FORCE LABEL FACING THE REAR OF THE VEHICLE.
# THE CROSSMEMBER IS INSTALLED SO THAT THE EXHAUST CLEARANCE HUMPS ARE CLOSED ON THE TOP AND OPEN ON THE BOTTOM.
# TO UTILIZE THE PROVIDED 7/16 HARDWARE IT IS NECESSARY TO ENLARGE THE HOLES IN THE FRAME RAILS WITH A 1/2" DRILL. IF THE INSTALLER CHOOSES TO UTILZE THE STOCK SIZE 3/8 HARDWARE, IT IS STRONGLY RECOMMENDED THAT THE INSTALLER OBTAIN GRADE 8 FASTENERS AND WASHERS TO COMPENSATE.
73-77 GM A-Body
