View Full Version : HOT ROD dynos 4.8 LS at 1200HP! (SEP Issue)
ajjones44
07-20-2011, 08:39 AM
Just wanted to get some input on the little 4.8 and its 1200hp Dyno run at 26psi. These little engines are cheaper than the 5.3s. Internals were stock. Intake was a fast 102 and it wore a pair of Total Engine Airflow heads. Twin turbo setup with 76mm turbos. Did anyone read the article?
sr73bu
07-20-2011, 08:56 AM
I'll have to check out the article... my truck has a 4.8 in it... little bugger moves pretty nice... even with the factory "knock"....haha
-Sean
Flash68
07-20-2011, 09:17 AM
I read it. They were actually trying to grenade it to find the limit. Wow. Beyond impressive. Running race gas but still...
Steve1968LS2
07-20-2011, 09:50 AM
I was there at Westech when they did it.. pretty cool.. They kept TRYING to blow it up..
Of course living on the dyno is a bit different than in a car.. but still, that's a LOT of hp.
Nessumsar
07-20-2011, 12:22 PM
From the little research I have done those truck internals are safe to ~1000hp, but 1200 is pretty amazing. Those little engines are pretty amazing; heck, you can put a turbo, cam/springs, and injectors on a stock 5.3 and make over 600 hp on pump gas.
CFster
07-20-2011, 04:26 PM
I think the heads will start lifting pretty quick though - especially over 700hp. Head bolts are the weak spot.
Z06killinSBF
07-20-2011, 05:44 PM
I believe they studded it. For what work that was done on it, was nice. TEA ported heads, NICE!!
406 Q-ship
07-21-2011, 07:23 AM
They didn't stud it, just opened the ring end gap was the only change for the short block. Of course it would never survive long term in a vehicle at 26 psi, but 8 psi on the street and 15 psi on race gas would be a blast (hopefully not really a blast!). If it did let go then a drop in bullet would be a wrecking yard away.
BulldawgMusclecars
08-02-2011, 09:54 AM
Interesting article. I just picked up a 4.8 last night, a trade towards labor on a customer's car, and I am planning a similar turbo build (just not quite as much boost!). Destination for the motor is likely going to be a Porsche 944, which I also got in trade for labor.
ajjones44
08-02-2011, 10:17 AM
Sounds like you have the potential for a nice setup
TT302Z28
08-02-2011, 01:06 PM
ok...now let's see the same setup but on an LQ9!
BulldawgMusclecars
08-02-2011, 03:16 PM
I have one of those too, but its going in another project. I figure 600hp or so will be plenty, esp with the stock transaxle! If (when) the transaxle barfs I have another plan for it though.
