View Full Version : Front Brake Hard Lines - what to do
69lt4
06-23-2005, 05:22 PM
What are people using for hard lines in the front in a 4 wheel disc brake set-up. I have a 69 camaro with Baer 4 wheel disc brakes. I was planning on running the stock front to rear line (2 piece) with the adjustable proportional valve spliced in. I'm not sure about the front lines. Bending lines is not one of my skills.
Kevin
68BNUT
06-24-2005, 07:48 AM
Inline tube sells all the hard lines you could want. Pre bent and flared just for you.
69lt4
06-24-2005, 03:38 PM
68Bnut,
Talked to Inline Tube, they are local to me so I would like to purchase from them. They recommended the Power Drum Brake lines if I want to install an adjustable proportional valve. After I looked up the kit, I can't figure out why the front line kit has 4 pieces. Any idea?
Kevin
1Bad68camaro
06-28-2005, 08:39 PM
I got them from another company, but my kit had 4 because two of them were the short ones that run from the master cylinder to that block mounted below it.
68BNUT
06-29-2005, 07:01 AM
Yeah that would seem right. I had the 2 curly" lines from master cylinder to distribution block then from there 2 more lines that go out to each wheel.
