rocketrod
07-17-2011, 07:35 AM
Transmission, dipstick and tv cable SOLD
The following items are still available:
Pat's 10" Torque lock-up converter with 2800 rpm stall - $400 shipped
Bowtie Overdrive 2004R Transmission Crossmember p/n XMCA67692 - $130 shipped
ORIGINAL AD
This is a complete 200-R4 setup I removed from my 69 Camaro. Transmission built by Brian Hoffer, who is a well respected 200-R4 builder on the www.TurboBuick.com (http://www.turbobuick.com/) forum. Transmission was built to handle 700HP.
The transmission and all parts described below were purchased in Feb 2006 and have less than 100 miles on them and cost over $2500.00. I am asking $XXXX, call 309-6four8-5six80. Prefer local pickup, or I can meet you somewhere in between if your within a reasonable driving distance.
Here is what's included:
Lokar Hi-Tech Flexible Braided Stainless Transmission Dipstick p/n TD3200RFM
Lokar Stainless Steel Hi-Tech Kickdown Kit p/n KDP-2200RHT
Transmission has -6AN fittings for transmission output/input lines
Transmission is out of a Monte Carlo SS, CQ code and includes the following components:
CK Performance billet drum
CK Performance hardened input shaft
TCI lockup kit
550 & 400 boost valves
694 GN servo
Roller bearings (everywhere factory thrust washers were)
Hardened sun shell
10 vane pump with rev kit (hardened rings)
Wide red band Alto clutches
OD has 3 clutches (4 induces drag)
7 direct clutches, and 5 forward
Art Carr deep aluminum pan
Speedo gears for a 3.73 with 26in tall tires
ORIGINAL AD
TCI lockup kit
694 GN servo
Hardened sun shell
