View Full Version : 69 camaro mini tub only help!!
69blackwhss
07-10-2011, 09:58 AM
Hey I have a 69 Camaro an was thinking of a mini tub but don't want to do the leaf spring an gas tank I just want the mini tub but would it even help me to put a fatter tire on the rear if that's all I do? Am looking for some mesh wheel in thing a 17-18 front an 18-20 inch rims on rear thanks for any help. Am new on here an still need to get pics of my Camaro up
PTS
07-10-2011, 12:45 PM
Hello,
Here are some pictures of wheels from Genuine Boyds that can be built in 17",18", and 20" in virtually any width and 1/8" backspace increments to fit your car. Let me know if you have any questions and I will be glad to help with maximizing your fitment.
Regards,
Perry
PTS
https://static1.pt-content.com/images/pt/2011/03/pt_01-1.jpghttps://static1.pt-content.com/images/pt/2011/05/pt_10-1.jpghttps://static1.pt-content.com/images/pt/2011/04/pt_04-1.jpghttps://static1.pt-content.com/images/pt/2011/03/pt_09-1.jpg
69blackwhss
07-10-2011, 01:23 PM
What's the prices on the pt-10? An do u carry an Forgeline.com
Vr3p
Zx3r
Wc3
Xxr wheels Xxr 006.
Tsw Valencia *
Mrr *gt-7 thanks an I saw on a other pos u had a sale going on rite now ;)
Hello,
Regards,
Perry
PTS
PTS
07-10-2011, 02:31 PM
Vr3p
Zx3r
Wc3
Xxr wheels Xxr 006.
Tsw Valencia *
Hello,
I do carry Forgeline and I will give the best deal.... PM on the way!
Regards,
Perry
PTS
69blackwhss
07-10-2011, 11:26 PM
Does
Anyone know about the mini tub stuff ?
1969CamaroRS
07-11-2011, 09:51 AM
If you are keeping leaf springs and I am assuming without relocating the shock mounts, you won't get that much extra space I don't think. And without notching your gas tank exhaust clearance could be an issue.
You could probably measure and figure out how much extra space by comparing the where the shock mounts, and springs are compared to the tubs (that would move into the frame rails since they are notched). Subtract the space the shocks/springs are from the framerails, and that should give you how much extra room just adding the mini-tubs would give you, my guess is maybe 1" if that. Hope that makes sense.
This thread might help you visualize things:
https://www.pro-touring.com/showthread.php?46900-The-Novice-s-guide-to-mini-tubbing-a-68-69-Camaro
Hope this helps.
JEFFTATE
07-11-2011, 10:14 AM
When you mini-tub a first-gen camaro , you have to move the upper shock mounts inward.( They are in the way )
When those upper shock mounts get moved , you have to move the leaf-springs too , and that results in a notched gas tank .
So , it's kinda' all or nothing .
Now , you could just do a grind , notch , and weld on the rear inner fenderwell sheetmetal that is attached to the rear frame-rail .
But you would only gain maybe 1/2 inch ???
You can fit a 9.5" tire on the back of a stock '69 with 5.5" backspacing .
1969CamaroRS
07-11-2011, 12:13 PM
You might be able to relocate the shock mounts and get the DSE offset shackles and then just dump the exhaust at the rear axle, if you wanted to save on a tank.
When I was thinking about Mini-tubbing it actually ended up being just about the same to get G-Bar (4-link with coil-overs) when all was said and done. Then you gain the ability to set ride height and some tun-ability. Also Required less cutting since I didn't have to weld in a new shock tower and depending on the exhaust size you are planning on running you might even be able to get away with the stock tank or just have it minorly notched to clear.
Just some more ideas, definitely agree with Jeff above its kind of an all or nothing type of thing. But I'd look into G-Bar/G-Link, maybe give Frank @ Prodigy a call he knows his stuff around this type of thing (where I got my Tubs, G-Bar and rear-end setup from him).
69blackwhss
07-12-2011, 02:20 AM
Thanks guys my exhaust is dumps over the rear end gives it a rolling sound but I run cut outs all the time lol I would like the g bar Rhodes r nice but I don't think I would use it like u should for the money idk I'll look at it angin it's about time for body work bit should just do it all at once an I say mini tub is out now from what u guys r telling me a inch for the extra money not smart move in my book so maybe g bar then thanks again
chops101
07-13-2011, 09:23 AM
You can mini tub a '69, use existing leafs, exhaust out the back and stock tank.
Not heresay, or opinion, this is what I did:
My wheelhouses were patched, so I needed new metal regardless of whether stock or extended tubs.
I cut the old wheelhouses out to the frame rails.
Relocated shocks to inboard of the leafs.
I used GLA tubs, which do not require notching rails.
1.25" inboard each side for the leafs. I made my own offset shackles, stronger than stock.
Cut/rewelded spring perches 1.25" inboard on 12 bolt
Stock tank, no mod necessary.
Shorter shocks with E1-E1 mounts
Exhaust left untouched - out the back
I opted for 10" rims. 11 would have been fine but could not justify the high price increase for 11's.
I'm running Nitto 305-35-18's.
315 would have fit fine also, but I found new, unused 305's on Craigslist for a very cheap price.
GLA tubs from Matts Classic Bowties. He consistently gives me the best prices on everything and I do check everywhere.
Rushforth 18x10 Livewires, 6.375" BS.
The Rushforth shop can hook you up correctly the first time and give you the best price.
69blackwhss
07-14-2011, 09:18 PM
Thanks Chops101 for the info did u have to do the rest of that after changing the inner fenders? R dis u just want to to get more of a tire?
rocketrod
07-15-2011, 03:14 AM
I am not trying to hijack this thread, but could you provide any pics of your install?
69blackwhss
07-15-2011, 08:47 AM
That would be nice ;)
GaRys69
07-15-2011, 09:42 AM
What is GLA?
Are these mini-mini tubs or stock tub with a filler added in?
69blackwhss
07-22-2011, 12:54 PM
What if I did a coil over kit in the rear an do just the mini tub metal only how wide a rid could I go then?
69blackwhss
07-23-2011, 04:55 AM
Anyone?
Gitter Dun
07-23-2011, 11:10 AM
I mini-tubbed my '69 to fit 325's without relocating leaf springs. You will have to relocate the tops of your shock mounts as close to the outside of the frame rail that you can get. You will also have to roll the lips on your quarter panels.
https://static1.pt-content.com/images/pt/2011/07/325sandminitub041-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub040-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub039-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub038-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub037-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub036-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub035-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub034-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub033-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub032-1.jpg
https://static1.pt-content.com/images/pt/2011/07/325sandminitub031-1.jpg
Gitter Dun
07-23-2011, 11:24 AM
If yo want to run your exhaust all the way out the back you will have to narrow your tank.
https://static1.pt-content.com/images/pt/2011/03/WattsLink096-1.jpg
BuzzKillian
07-23-2011, 01:55 PM
I found some wider than stock inner wheelhousings made by Dynacorn. part no. [DYN-1041FD&GD] $160 on the site I found them on. (they are not a sponsor, so no link)
69blackwhss
07-23-2011, 03:00 PM
Thanks for the pics looks good with that tire on there
69blackwhss
07-23-2011, 03:02 PM
cool I'll check them out I see u went ls1 am
Building one now for my swap did u happen to use hooker headers mounts an headers by any chance
PTS
07-23-2011, 07:49 PM
Great Information...
69blackwhss
07-23-2011, 08:43 PM
It's is great info
BuzzKillian
07-26-2011, 05:02 PM
I made my mounts, they locate the back of the block in the same location as stock. I used Doug's Headers.
https://www.pro-touring.com/showthrea...ht=#post765951 see post # 54
This link has a drawing of the mounts.
