View Full Version : First time down the 1/4 with the T56 Magnum
rob07002
07-09-2011, 07:36 PM
http://www.youtube.com/watch?v=naP5UGOpAbQ&feature=youtube_gdata_player
naP5UGOpAbQ&sns=em
Was hoping for high 11's and 120+ mph, but as you can see I left like a minivan from the can-can sale at Shoprite and the air/temp this Friday was real crap. Even the bracket racers and forced ind guys were off by 3-4 tenths and 3-4 mph. Had the timing too high, so it was breaking up a bit on the top. Was all set to go again, right press in the mt radials, etc, etc and the skies opened up.
I suppose it's decent on a street tune, but leaving a lot on the table. Looking into some carbs, and more tuning and WILL get low 11's and 125+ next time.
Shaker455
07-09-2011, 08:22 PM
Well Rob it looked nice and with some tuning you may pick up a bit....see ya in the carb & tuning forum.
Jeff
67 ls1 vert
07-09-2011, 09:24 PM
do you have a roll bar under the top?
rob07002
07-10-2011, 08:08 AM
Yes sir. 4 point.
TheMeat
07-30-2011, 06:17 PM
Sounds nice and crisp! What's the motor set-up and exhaust?
Ray
rob07002
08-01-2011, 07:59 AM
Ray
Thanks Ray!
It was actually breaking up a bit on the top due to too much timing, air, and a slight lean condition. In the Carb section, I mention leaving a lot on the table with the current intake and carb. I am choking it with the current 850, so definitely need to go bigger while maintaining the street manners it has. I'll have a defferent intake and carb the next time.
The exhaust is:
Stainless Works 2" primary headers, 3" collectors to 3" pypes X pipe and 3" Flowmasters (they are hurting hp big time) to angled dumps. I plan on Magnaflo's and tail pipes this winter. I need to fab the tail pipes to fit around the G-Bar.
Thanks again,
Rob
Here are the motor specs:
540 BBC
Dart big m block
Eagle forged crank & rods
10.5:1 comp srp forged
Dart 310 pro1 aluminum heads out the box, no porting
Dart single plane intake
850 BG 4150
Aeromotive a1000 pump
Comp cams solid .256/.250 @ .50 duration, 108 lobe center
2" primary syainlessworks headers
T56 magnum w. 2.67 first gear
Moser 12 bolt 4:10 gears
Aluminum driveshaft
Msd ignition
Msd pro billet dist
38 deg total timing
BonzoHansen
08-01-2011, 08:07 AM
the camera guy is better with the green light reaction :)
Sweet car, I hope to see it one day
rob07002
08-01-2011, 08:18 AM
Ouch! LOL! I know. I wasn't concerned with my reaction time. First trip with the drag radials and was purely interested in seeing how it all worked. I wasn't about to side step the clutch at 4000 with so many new components. I was working toward a harder launch, then the skies opened up and ended the day early.
I plan to go to next year's RTTS for sure, so hope to see you there Scott.
intocarss
08-01-2011, 12:08 PM
Nice car nice pass.
wmhjr
08-01-2011, 12:33 PM
Yes sir. 4 point.
Interesting. It's cool that they let you run. You're not legal. 4 point ain't good enough for IHRA/NHRA for verts faster than 13.49. Unfortunately, I know. At least you can bolt in if you add a 5th point (assuming your roll bar setup meets the rest of the requirements). With mine, I'd have to weld directly to the frame so that's out.
69X22
08-01-2011, 02:53 PM
Sound like you did a pretty good job of shifting. What gear did you go through the traps in?
intocarss
08-01-2011, 04:09 PM
2011 IHRA rulebook has the roll bar cutoff at 11.49 in the 1/4 and 7.49 in the 1/8 mile. Quite a bit slower, if it's a convertible. Oh, and one track I run at says you have to have a roll bar to run in Top (0-7.99) no matter what your dial-in. Individual tracks can make and/or enforce most any deal they want
wmhjr
08-02-2011, 04:58 AM
The OP was 1/4 mile, in a convertible. 13.49 my man. That's what I was talking about.
Tracks often do their own thing, but over recent years I've observed them getting more and more picky about any safety enforcement due to liability.
devwil68
08-02-2011, 06:24 AM
looks great, and goes well! nice job!
rob07002
08-03-2011, 09:00 AM
It was a rental day and it doesn't see the 1/4 that much to warrant a 6 point. The 4 point stiffens the car up while providing some rollover pretection.
rob07002
08-03-2011, 09:01 AM
Thanks. Through the traps in 4th at around 6100
wmhjr
08-03-2011, 10:04 AM
Totally agree. Local track here doesn't seem to care. If you're 13.49 or better, you're off the track - period - in a vert without a 5-6pt cage. It's very cool that your track is more friendly. Wish more were like that.
TheMeat
08-03-2011, 04:52 PM
Thanks Ray!
The exhaust is:
Thanks again,
Rob
540 BBC
Dart big m block
850 BG 4150
Aluminum driveshaft
Msd ignition
Msd pro billet dist
38 deg total timing
restrictions? Whats your vac @ WOT?
rob07002
08-03-2011, 09:00 PM
Don't get me wrong, I'm all for being safe, but most modern mustang, camaro, and corvette verts are going faster than that off the showroom. Not that my 40+ year old camaro is anywhere nearly as safely designed as those cars, but whose installing 6 point bars in their brand new gt500 vert that sees the track once in a while. Time for the Nhra to revisit.
rob07002
08-03-2011, 09:02 PM
Good question, I haven't checked. Will have to put a vac gauge on it and see.
wmhjr
08-04-2011, 03:44 AM
Nice thought but will never happen. Attorneys. If anything it will get worse.
TheMeat
08-04-2011, 09:54 AM
My combo has 1 5/8 headers amd a 750 carb with a DP intake. I am pulling 8" vac @ WOT...too much but too poor currently to change stuff!
Rybar
08-04-2011, 09:58 AM
Nice run Rob, car sounded good.
Cannon
09-12-2011, 07:09 AM
Whats the point in signing the waiver form then? I thought that prevents any BS coming back to the track guys incase your an idiot?
Speedy911
09-19-2011, 11:21 AM
Nice car, can't wait to see it pull some lower numbers
AintQik
09-21-2011, 08:34 AM
Nice. I'm running a big block and T56 in my 67 and am 6 miles from that track! Hope to see you out there.
Samckitt
09-21-2011, 02:33 PM
Is that the close ratio T56 or the other one with 50% overdrive in 6th gear.
rob07002
10-03-2011, 07:35 AM
It's the close ratio box. T56 Magnum with the 2.66 first and .82 6th. I really like the gearing choice and actually use 6th with 4:10's and a 25.5" tall tire.
momsnova
10-03-2011, 08:58 AM
Rob,
Nice first pass! What clutch are you using?
rob07002
10-03-2011, 12:58 PM
Rob,
Mcleod street twin
