The GMR
07-08-2011, 07:13 PM
Never Compromise…
The GMR PT-R shocks were designed and developed exclusively for the pro-touring market with nothing but performance in mind. The concept was to create a shock that will dominate the pro-touring market just like our PT-R hubs. Built for the track but perfect for the street!
Benefits:
Insane Strength
Superior Reliability
Infinitely Adjustable
Completely Rebuildable
OEM Longevity
Features:
Beautifully anodized aircraft quality billet aluminum construction with extremely strong steel shock body providing OEM longevity.
Clearly marked, ergonomic knob design is easy to use even while wearing gloves.
Individual detents make each click of adjustment easy to feel while turning. Each of the twenty levels of adjustment offers precise compression damping control ranging from very soft to very firm.
Reservoir mount bolts securely to the shock and includes a quad sealed fluid transfer tube.
Machined with our own truncated thread design for ultimate strength and trouble free spring preload and ride height adjustments.
Large 3/4” diameter shafts have a minimum tensile strength of 100,000 pounds per square inch. They are hard chromed and micro-polished to a 6 RA finish for extended seal life.
Shock cylinders are precision bored to within +/- .001, then honed after cadmium plating to remove buildup for a tight piston seal and optimum valving function.
Integrated piggyback style mounted light weight hard anodized 6063 aluminum alloy reservoirs dissipate heat quickly and will not rust due to gas charging contamination.
Urethane foam bump stop included to cushion when bottoming.
Aluminum components are machined from aircraft quality billet. Steel Teflon lined spherical bearings for smooth articulation and long life with no metal to metal contact.
Shocks are 15.5 inches fully extended with 4.5 inches of stroke.
The PT-R shocks share the exact same technology that went into the GMR Trophy Truck!
All GMR PT-R shocks are manufactured in very precise runs to ensure quality each and every time. This is the last shock you will ever have to buy for your Pro-Touring car!
$850 Each
$900 With Matching Silver Eibach Springs
Shocks are in Stock and Ready to Ship. Mention Pro-Touring.com when you order and shipping is FREE! (inside the US)
Benefits:
Insane Strength
OEM Longevity
Features:
$850 Each
