View Full Version : 6 Speed (T-56) vs. 5 Speed (TKO 600)
Besides the obvious of having 6 gears vs 5 gears what are the reasons guys go with a 6 speeds over a 5 speeds. My foucs here is on Tremec only.
Is it for max cruising potential (example: being able to run 80 mph at only 2000 rpm's)??
Is it for image (hey I have a 6 speed)?
Gear selection ( 1 thru 6)?
Torque?
Other?
Just looking for feedback/opinions of why someone would go 6 speed over 5 speed.
Any feedback would be appreciated. Thank, Scott
68RallySport
08-31-2004, 09:20 AM
My friend has 3.23 out back and at 100mph in the 6th the RPM is only 2200!!!
Thats with a 275/45/17 rear....
David
(im going with the six speed for that reason....)
parsonsj
08-31-2004, 09:26 AM
You won't use 6th gear on the track. The 0.5 gear ratio simply won't work there unless your vehicle is going 190+.
What RPM will it be at a useful speed (say 70 mph)? Will your engine be happy cruising at such an RPM-level?
If not, the 0.82 overdrive of the TKO is likely a better choice, especially if your engine is designed for mid or high RPM power.
jp
Ralph LoGrasso
08-31-2004, 12:27 PM
4th Gen LS1 Camaros actually top out in 5th gear (162mph), rather than 6th, so like John said, I don't think 6th would play a big part up top until you're REALLY going fast. I'm going with the T56 for strength though(G-force upgraded - 900hp rating).
68RallySport
08-31-2004, 06:01 PM
but 6th is awsome for cruising on the freeway, no power but it really wants to coast. If u need to get somewhere 5th is always there. In most cars that have v8's, that i have driven, u barely need to touch the gas on the freeway or in anycase to maintain speed. On the freeway with the t56 u barely let ur foot rest on the pedal in 6th and ur cruising...
David
