View Full Version : L92 in 68 camaro fuel pump?
1981silverz28
07-04-2011, 06:12 PM
I'm helping a buddy put an L92 in a 68 camaro and would like to know what the best fuel setup would be . He has just installed a new stock replacement tank and he doesnt really want to buy another tank . I have looked at this pickup http://www.robbmcperformance.com/products/1078_gmsend.htmlcombined with a Aero A1000 pump . What else do we need ? regulator ,return line ,etc ?
dhutton
07-05-2011, 09:06 AM
You need a Corvette regulator/filter. I also suggest you get the Aeromotove controller if you are going to run that pump to avoid overheating your fuel. The tank should also have a sump/baffle if you plan to run anything less than about 3/4 of a tank.
Why the 1/2 sending unit? The Corvette regulator is 3/8.
There are better options out there. Search for Vapor Works in this forum.
1981silverz28
07-05-2011, 06:34 PM
dhutton , Thanks for the info . I will check vapor Works tonight .
CarlC
07-05-2011, 09:45 PM
An A1000 for that engine is like hitting a snail with a sledge hammer. It's way too much pump unless you have gobs of boost or a serious amount of horsepower. The C5 FFR may not work well with it either.
