View Full Version : hidden reverse light ideas
icemanrd19
07-04-2011, 05:53 PM
Has anyone thought of a creative way to hid the reverse lights on a car? I really dont want to put those ugly reverse lights on my car. I was thinking about getting some mini reverse lights and somehow mounting them inside the bumper. Figured get a set of chrome reverse lights might not look bad in the chrome bumper. I also thought about hiding them underneath the car somehow.
Car is a 67 camaro
absintheisfun
07-05-2011, 03:32 AM
I've been putting some thought into this as well....I haven't really come up with much, but thought that if I could fabricate a bracket, in the recess of the rear bumper where the license plate goes I could get something there like a long skinny strip of white LED's.
I'm going to be watching this though to see if anyone came up with anything good!
neki67
07-05-2011, 04:51 AM
I also would appreciate some good ideas!
Oats
07-05-2011, 02:36 PM
Also curious where this thread goes....
shep
07-05-2011, 07:24 PM
A little pricey but these would work well http://www.visibolt.com/Bolts.htm
nekkidhillbilly
07-06-2011, 08:51 PM
i dont see how those would make it possible to see how to back up
bigshotsho93
07-06-2011, 08:59 PM
what about something in a license plate frame but hooked to the reverse lights so they only come on when in reverse. maybe a few led strips, not sure if it would be bright enough i have not used any clear leds so not sure how visible the light would be due to the leds being directional.
Ash
07-07-2011, 02:54 AM
Hmm...there really isn't a solution for this on the market, is there?
icemanrd19
07-07-2011, 04:33 PM
nope. I think a vendor should be reading this. lol. I would love some LED bright lights that also act as license plate bolts. I think ill head to a motorcycle shop and see if they have any options as far as small lighting.
racedaddy
07-07-2011, 04:52 PM
in the mini truck scene there are license plate frames that drop down to drive, what about having them on an actuator so they drop down from the rear valance when they come on and then retract when they are off....or if you want exhaust tips you can buy some that are surrounded by LED's, these are cheap and are sold at autozone-not sure how bright they are
The Stickman
07-07-2011, 05:33 PM
Try this. It's what I did to my wife's car.
http://www.youtube.com/watch?v=47Ug5Deq2sY
icemanrd19
07-07-2011, 05:40 PM
not a bad idea. I think ill just put a thin strip by the bumper
Bigblue73
07-19-2011, 04:49 AM
This all depends on how far you want to take this. I have 48 (5mm) LED arrays that can either be hardwired or use an 1156 connection. These are really bright. I use 24 white in the day time running lights and 24 amber. Brad has seen the driving lights in the front of my car during the day. At night, they have no problem illuminating my entire house front at about 40 yards away. The outside diameter is 2.06 inches. Honestly, if you would mount it angled under the inside of back valance it WILL light up the rear of the car for you to see. The issue becomes a small housing to protect it and the electrical connection. Maybe an early ford mustang unit?
As far as strip lighting, these styles are available and basically stick on to any panel or housing using double sided tape. I would recommend a different style of tape if you are considering these for an automotive installation. These are not bright at all and are only designed to add color to items since the LED size is quite small.
Bigblue73
07-19-2011, 06:10 AM
So what about something like this?
These are very similar to the ones that Neil installed.
TA219
07-22-2011, 04:42 AM
I was able to accomplish this by attaching lights to the inner quarter panel (that attaches to the wheel well and inner rear valance) I used rectangular lights and placed them at an angle. It provides a decent amount of light (although it does me no good since I have 5% tint on the back glass now!).
Forgive what a mess the car was, this was after I initially installed them which was the same time that wet sanding and 100 other things were going on.
https://static1.pt-content.com/images/pt/2011/07/21638054002_large-1.jpg
icemanrd19
07-22-2011, 03:56 PM
yup. Im just going to hide them under like this. THanks guys
nekkidhillbilly
07-24-2011, 11:56 AM
i have a set of them on my truck with the oem ones and didnt really help much
gotmy68goat
08-02-2011, 03:45 AM
I haven't done it, but you might check with a company that supplies light bars for police vehicles. The lights used are extremely bright led's and fairly compact.
Bigblue73
08-02-2011, 07:43 AM
Trailer back up lights is another alternative. The units are completely sealed.
dontlifttoshift
08-02-2011, 09:13 AM
I hide mine in the garbage can, they become totally invisible then.
I know, real helpful. :D
scomp890
08-28-2011, 05:36 AM
Contrary to popular belief... Back up lamps are there to show someone else that you are backing up, and not so the driver can see what's behind him/her.
Here is a small white LED that is designed to mount into a 3/4 inch hole.
https://static1.pt-content.com/images/pt/2011/08/493411-1.jpg
https://static1.pt-content.com/images/pt/2011/08/49341-1.gif
These would be great mounted into a license plate frame.
icemanrd19
08-28-2011, 05:47 AM
^^^^^^ where do you get that?
scomp890
08-28-2011, 04:46 PM
http://www.grote.com/product.php?product_number=49341&x=13&y=7
You can get them at any place that sells truck parts.
icemanrd19
11-15-2015, 07:31 PM
we mounted two angel eye leds by the bumper bracket tucked closely underneath the bumper. This doesn't look bad since the lense was black and the car was black but I'm still looking for another solution. I found some chrome led angel eyes that i mounted in the bumper and it just didn't look right. I might look for a option under the car that is hidden
Richard454
12-08-2015, 10:15 AM
Pretty much hidden-
https://www.youtube.com/watch?v=tHbw8rdbVSU
spacepirate
12-08-2015, 03:27 PM
Holy crap ^^ that is awesome!!
icemanrd19
12-08-2015, 06:51 PM
wow that is pimp
raustinss
12-08-2015, 07:33 PM
Ok where did that come from
icemanrd19
11-27-2016, 07:04 PM
Played around today and decided to mount the new reverse lights. They are a 1/4" to the fender side of the lower bumper bolt and 1/4" higher than the bolt. You can't see them standing behind the csr but they do give decent amount of light. I ordered 2 more LED bolt bulbs that are brighter and have 3 leds built in them. Go to home Depot and get some magnets to help you determine where you want to drill the hole in your tail pan. Drill the hole out, hook up the red wire to the green reverse wire, ground the black wire on the bulb to the taillight nut and your done. The light on the left is the one I'm going with. I also ordered a led license plate light.
https://static1.pt-content.com/images/pt/2016/11/15171094_10100995555461156_2435130994018-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/15171094_10100995555461156_2435130994018035967_n_1 .jpg.html)
https://static1.pt-content.com/images/pt/2016/11/15193582_10100995555416246_3796075172068-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/15193582_10100995555416246_3796075172068290547_n.j pg.html)
https://static1.pt-content.com/images/pt/2016/11/15253538_10100995555441196_3984728300326-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/15253538_10100995555441196_3984728300326121837_n.j pg.html)
