View Full Version : Fuel Gauge going past full?
Vicinity
07-03-2011, 09:19 AM
My fuel gauge reads somewhere down south when I turn on the acc setting on my key. It's an autometer fuel gauge and american autowire wiring kit.
Is the sending unit bad? That's the only thing I can think of...
77thor
07-04-2011, 12:31 PM
You have an OPEN circuit somewhere.
The sender should read 0 ohms for EMPTY and 90 ohms for a FULL tank.
Vicinity
07-07-2011, 04:47 AM
It's doing it without the sender hooked up.
John Wright
07-07-2011, 05:39 AM
~ (infinity) is an open circuit.....
0 ohms is not an open circuit, it is complete continuity....so maybe it is grounded somewhere
between the gauge and the sending unit.
77thor
07-07-2011, 05:49 AM
Yes, I agree... But he stated in the title that the "Fuel gauge going past full" so it must be an OPEN circuit....
dontlifttoshift
07-07-2011, 05:54 AM
That's why. the gauge think there is a way full tank because you have no sender hooked up. If you ground the sender wire from the gauge it should read empty
John Wright
07-07-2011, 05:58 AM
LOL...wow, I need to examine my comprehension skills.....duh. Somehow I read that as going past empty. Nevermind, I'll go back to sleep now.
Vicinity
07-07-2011, 07:24 AM
It's doing it with both the sender attached and the sender unattached, which is why I don't understand how it's happening. So, do I ground the ground, ground the sender and 12v to the ignition wire?
The ignition and the ground wires are fine, they're all daisy chained on the back on the panel and all the other gauges are operating fine.
dontlifttoshift
07-07-2011, 07:36 AM
If it does it with the sender attached make sure the gas tank is grounded, too. the sending unit grounds through the tank, in theory. I always put a separate ground wire under one of the sending unit attachment screws and run it to the frame to help eliminate inaccurate readings. Try that first.
If that doesn't work take the wire that goes from the gauge to the sender, disconnect from the sender, and then ground it. gauge should read empty at that point. If it does your gauge is probably good and you have ground issues.
Clear as mud?
Donny
Vicinity
07-07-2011, 07:38 AM
Got it. I don't remember a ground on the sending unit, that could actually be it. The sending unit on my tank was beat to hell.
Vicinity
07-07-2011, 05:41 PM
Yeah, not ground at the sender. The sender was also REALLY corroded. I'm just going to replace it. Couldn't hurt.
Should I get a sending unit with a return?
dontlifttoshift
07-08-2011, 05:54 AM
Glad you got it nailed down.
As far as the return, I would rather have it and not need it than need it and not have it.
John Wright
07-08-2011, 06:07 AM
Glad you figured it out.....I need to work on my wife's Tahoe....her gauge is reading empty but only when you fill it all the way up to the top....anything below 3/4's it seems to read fine.
