View Full Version : Pontiac 455/535 horsepower longblock and parts for sale
Later-A-body
06-24-2011, 07:59 PM
For Sale: Complete 535 horsepower Pontiac 455.This is the current engine in my 1973 Grand Am. The motor was built by Ken Brewer of Pacific Performance Racing in 2008. It has a total of approximately 2000 miles. All parts are top shelf components that are listed below. This is a very powerful motor that produced 437 HP, and 457 ft. lbs of torque to the wheels on a Mustang Dyno. The engine is currently installed in the car and is running. It can be seen in person, or a video if needed for varification. I am going in a different direction with the car.
Block: 1973 455. Zero decked, line bored, 2 bolt with ARP studs. All professionally balanced.
Pistons: BRC custom forged lightweight .045, double spirolox, compression 10.3:1
Cam: Comp Hyd. Roller, .360 lobe, 242/248, 110LSA
Crank: Aftermarket cast 4.21 stroke.
Rods: Forged Tomahawk 4340 Ultra-lightweight I-beam with lightweight pins, ARP bolts.
Oil Pan: Milodon 7 quart kick out.
Cylinder Heads: Edelbrock SD Performance ported 312cfm, relieved for 1.65 rockers.
Valves: 2.11/1.72
Rockers: PRW 1.65 full roller.
Pushrods: Comp Cam heavy wall 5/16"
Longblock price: $4500
Other Parts for sale
Victor EFI (Torker II) Custom Ported by SD Performance for 312 cfm heads, includes Edelbrock fuel rails and custom black braided fuel lines with AN fittings. $375 SOLD.
Ford 42 lb. injectors: $200
Accufab 1215 cfm polished 4 barrel throttle body: $250 SOLD.
Wilson Manifolds 1.5" open spacer: $75 SOLD.
McLeod SFI Scattershield powdercoated black: $250
Billet Flywheel 24.5 lbs: $100
IMI mini starter: $100
Custom built 1-7/8-2" ceramic coated stepped round port headers for '73-'77 A-body: $750.
Retrotek-Speed EFI computer and wiring harness: $550. SOLD.
MSD 6AL-2 used x 1 month. $150
Custom Built 8-pin HEI for EFI Large cap: $125
Custom Built 8-pin HEI for EFI Small Cap $150 SOLD.
Contact Sean: 949-500-8940
Steve88
06-24-2011, 09:43 PM
PM sent on thr throttle body. Thanks
Roadrage David
06-25-2011, 12:41 AM
Have a intrest on the Victoor efi TII with fuel rail any pictures ??. also how many hp will the ford 42lb injectors suport..
ryeguy2006a
06-28-2011, 10:46 AM
Interested in the IMI mini starter.
ryeguy2006a
06-29-2011, 11:34 AM
Pictures?
Later-A-body
07-02-2011, 11:44 AM
The remaining parts are listed below. May seperate engine if there is interest in the shortblock or Edelbrock heads separatly.
Longblock as described in original thread: $4500
Shortblock: $3000
Edelbrock SD ported heads 312cfm with flow sheets. Includes matching ARP head bolts: $1650.
Ford 42lb injectors: $200
MSD 6AL2: $150
HEI 8-pin module distributor for EFI: $125
Round Port Headers custom built 1-7/8" - 2" ceramic coated stepped for '73-'77 A-body: $750.
Contact Sean
949-500-8940
Later-A-body
07-06-2011, 09:27 PM
535 horsepower Pontiac 455 shortblock.The motor was built by Ken Brewer of Pacific Performance Racing in 2008. It has a total of approximately 2000 miles. All parts are top shelf components that are listed below. This is a very powerful motor that produced 437 HP, and 457 ft. lbs of torque to the wheels on a Mustang Dyno. The engine is currently installed in the car and is running. It can be seen in person, or a video if needed for varification. I am going in a different direction with the car.
Shortblock: $2650 less roller lifters.
MSD 6AL2: $150
HEI distributor with 8-pin module for EFI: $125
Contact Sean
949-500-8940__________________
wmhjr
07-07-2011, 05:29 AM
Guys, this stuff is a great deal. Ken "Ace" Brewer is a heck of a guy and builds a great motor. He's also responsible for getting us Poncho guys aftermarket parts that were previously unavailable. And assuming somebody bought those heads, you got a great deal. SD is the best in the business for Pontiac heads - bar none. Dave B up at SD does a fantastic job and not only are the flow numbers on his heads "honest" but the heads aren't just hogged out - they perform.
There are a few names out there in the Pontiac world, and both Ace Brewer at PP and Dave at SD are very high up on that list.
critter
07-07-2011, 06:32 AM
Your Pm box is full. What CC are those heads?
grenade inspector
07-07-2011, 06:34 PM
wrong coast.... nice setup, good luck
critter
07-07-2011, 06:35 PM
FYI, heads are sold. And not to me. :(
grenade inspector
07-08-2011, 07:15 PM
part number for the msd box?
Later-A-body
07-12-2011, 09:26 PM
Thanks for the comments on the parts. You are correct on the quality. I have sold most of the parts. The remaining parts are listed below.
Shortblock: 1973 455. Zero decked, line bored, 2 bolt with ARP studs. All professionally balanced.
Motor has approximately 2000 miles.
Shortblock: $2650 less roller lifters which were sold.
MSD 6AL2: $150 (Sale Pending)
Contact Sean
SShep71
07-17-2011, 08:35 PM
Sean, im in SD. I would like to talk about the shortblock and other parts. If you can gimme a call tomorrow. 5702337608
-Shep
