View Full Version : Upper control arm bolt repeatedly backing out
woodkd
06-24-2011, 12:02 PM
The right side upper control arm bolt (stock suspension) on my 69 camaro continues to back out and I have subsequently lost the washer, lock washer and bolt twice. After the first loss, I used loctite but this appears to have no effect. The bolt will back out after a couple hundred miles of driving. I suspect the issue to be related to the threads on the shaft. Any suggestions or ideas as to a cause or resolution are greatly appreciated.
Thanks in advance,
Ken
06-24-2011, 08:47 PM
go out to your local NAPA and buy a MOOG problem solver upper cross shaft pn: mg 5250 or summit...http://www.summitracing.com/parts/MOG-K5250/ ....before you pop an arm on the highway
