View Full Version : Trans cooler...Anyone used something similar to this?
DJW32
06-22-2011, 07:37 AM
Has anyone used a trans cooler similar to this:
http://www.summitracing.com/parts/RUS-651470/?rtype=10
I was wondering if they actually work efficiently. I plan on running one in-line with my factory radiator cooler.
SRD art
08-18-2011, 07:17 PM
A lot of 30's hot rodders use those and put them under the car on a frame rail because of the limited engine compartment space. Maybe post the question on the HAMB or a street rod forum I'll bet you'll find some feedback there.
Evldoer
08-18-2011, 10:36 PM
I think you would be fine with it as long as you are still using your factory rad. cooler. I dont know how well they work though as a stand alone cooler,I wouldnt feel safe anyways.
Rod
08-18-2011, 10:43 PM
efficiently, is not what those are, stack plate or finned work the best those tube ones work well as an additional cooler if that's you're primary cooler it should be a double pass and about 15" or longer
rrelco
09-01-2011, 09:21 PM
I had one similar and installed it in the inner fender well the trans temp was at 200+ i got rid of it and put a 18 x 9.5 Hayden in front of the radiator now its 150 to 180 if your auto crossing your car i don't suggest it.
