317millhand
06-21-2011, 03:04 PM
I have acquired a big block for my Chevelle so I have a good deal for someone on this one. This engine has not yet been started and has had over $6000 spent on it.
FRESH 406 solid roller SBC...great street/strip motor!! Well over 500hp/500lbs ft. Professionally built by Walker Performance in Hiram Georgia over the Summer. Receipts in hand for much more than my asking price. Here are the specs.
GM 400 block, -817 casting, 2 bolt mains with ARP bolts Bored .030” over, sq decked, align honed, bores honed with TQ plate Deck height is .014”
Scat 9000 series cast crank, 3.75” stroke
Scat 5.7” I-beam rods
Speed Pro 615CP30 hyper, coated skirt pistons, 12.5cc dish Balanced rotating assembly
Dart Iron Eagle 200cc heads, 64cc chambers, straight plugs Stage I port job with multi-angle competition valve job
New Ferrea 2.02/1.60” valves Comp Cam 943-16 springs, retainers, super locks, guide plates, stem seals ARP 7/16” rocker studs, 5/16” pushrods
Scorpion full roller rockers, 1.5 ratio Mr. Gasket 5801G head gaskets, .038” thick W/4.190” bore CR is calculated at 10.4...pump gas friendly.
Crane 118131 billet core Solid roller cam 282/290 adv; 242/250 @ .050” .580/.600” lift w/1.5 rockers LSA 106; installed at 102
Crower severe duty solid roller lifters w/pin oiling option
Cast aluminum timing cover with cam button Edelbrock RPM Air Gap intake, #75014 Endura-Shine coated MSD distributor and 6AL ignition box Holley
HP 750 double pumper carb Carter Hi-volume fuel pump w/braided hose to carb K&N 14 inch air cleaner Speed Pro moly rings, Clevite rod and main bearings Durabond cam bearings, brass freeze plugs Mellings standard oil pump Moroso 6 qt kickout pan w/matching pickup ARP pump shaft Motor has not been ran yet, so you can break it in. This engine is complete from the air cleaner to oil pan and balancer to flexplate. MSD box also included. Firm price of $4000 with engine cradle and you come pick it up. Will also trade to a 2008 and up ATV, good tools, g u n s, or who knows what. I just dont want to leave this engine sitting. Call Steve in Hazard, Ky. (606)438-9921
