View Full Version : Parking lights come on when applying brakes HELP
1973Firebird01
06-08-2011, 05:37 AM
I just finished putting in a 01 Trans Am dash in my 73 Firebird. I've had Autometer gauges in it for about 10 years now(old dash and now the new dash). I pulled the steering column out to replace it with a tilt unit out of a 78 Firebird then just put the old one back in. I had brake, turn signals, and hazards before, now when you step on the brakes all the lights (brake & front turn signal lamps) light up. While stepping on the brakes if I turn on the turn signal there is a quick flash of that side and then the lights just stay on. I've checked all the connections on the column, fuse box, body grounds, and replaced the flasher, brake & turn signal fuses, and brake light switch. The headlight switch is just hanging right now, I need to wire it to the 2001 headlight switch(still have to figure out that one). I did remove the courtsey lamp lights and harness and will replace later with led's.
Any help would be GREATLY APPRECIATED!!!!!! Wiring to me is like a bowl of noodles
Val
shep
06-08-2011, 06:38 PM
Sounds like you have a bulb shorted or a wire pinched somewhere.
1973Firebird01
06-09-2011, 05:19 AM
Found it! It ended up being the fuse for the gauges if that makes any sense. I pulled the fuse out and cleaned the ends put it in and they work just fine. While I hade the dash apart I also wired in the LED turn signals. It all works perfect now. Thanks for your sugestions!!!
Val
