Lenie
05-25-2011, 07:43 PM
I have a Richmond 5 speed and wanted to install the hurst competition shifter somewhat close to it's original position in the tunnel. Googled an old write up where David had manufactured a plate and adapter to reposition his so I used the write up and machined a plate out of aluminum but when it came to the adapter I wasn't quite clear on how to go about it so I pm'd David with a few questions. To make a short story a little shorter, David was no longer using his, went out and located it in his garage and sent it to me free of charge along w/a few helpful hints. Can't say it enough but thanks again David. Great forum community.
New plate on left, hurst plate on right. Now mounts 1 1/2" down and 1" forward.
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us/photo/my-images/199/drivetrain002.jpg/)
Welded on the adaper 1" forward and 2" to the center. Attached in a way that if I wanted to remove it and return part to original intent I could.
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us/photo/my-images/854/transtunnelandshifter01.jpg/)
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us/photo/my-images/705/transtunnelandshifter01.jpg/)
Hole to be cut in new tunnel.
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us/photo/my-images/853/transtunnelandshifter00.jpg/)
Fine tuning as to not cut hole larger than it needs to be.
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us/photo/my-images/862/transtunnelandshifter02.jpg/)
Installed and works perfect, now I need to figure out how to set stops and their reason for existence.
https://static1.pt-content.com/images/noimg.gif (http://imageshack.us/photo/my-images/189/transtunnelandshifter02.jpg/)
