zuess4u
05-23-2011, 08:19 AM
I didnt get anyones opinion on this, well because this thing just makes sense for this build.
Relocates shocks in board of frame rails
hides the shock mount in the bump of the trunk
Upper shock mount is MAYBE 1.5 lower then stock, might give more of a shock selection once lowered, as opposed to say like a CE shock mount, which lowers the upper mount a good 4", then if you lowered your car, you may be pressed in finding a shock that works.
Comes with two different degreed cups, one at 80 and one at 85 degrees, I think the 85 is used when your lower shock mounts are in the stock location.
Anyway this thing seems to cover some rear issues that many of you have had in the past years. take a look and tell me what you think.
Thanks Bob 623-326-8478
