    Results 1 to 20 of 31
      Scottsdale, AZ
      Is there a list of 200 tread wear tires/Manufactures
      So far I found Toyo's R888 & Nitto. What else?
      I looked at BFG since they sponsor but could not find a 200 tread wear tire???
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Sep 2010
      CDog, Toyo and Nitto come from the same. The Nitto Nt-05 is 200 and the R888 is 100. Kumbo has a 180. Goodyear has a 220. I was trying the same thing and found several companies with a +-200 treadware but not in my fat tire size 275-17 and 295-18. If you run anything below a 275-17 you will have more to choose from.
      I will try to find my list and post it. If you go to the manufactures pages (not the retail sites) you can read the size and spec sheets to find what you are looking for. I did notice at the track this past weekend (with BMW's and S2000 such cars) Some of the non mainstream companies offer 140 to 220 treadware tires. Problem is that I don't think they have the bigger sizes.
      Good luck
      Brett
      Scottsdale, AZ
      Quote Originally Posted by 67zo6Camaro View Post
      I will try to find my list and post it. If you go to the manufactures pages (not the retail sites) you can read the size and spec sheets to find what you are looking for. I did notice at the track this past weekend (with BMW's and S2000 such cars) Some of the none mainstream companies offer 140 to 220 treadware tires. Problem is that I don't think they have the bigger sizes.
      Good luck
      Brett
      Awesome thank you! I've got 18 inch Forgelines on order. I should be able to fit a 245/18 up front and 335/18 on rear. The websites are not very clear.....????
      Right now the car has 245/18 & 325/19 on rear.
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Nor Cal
      The 3 most popular I have seen over the past year in the 200+ category are:
      NT-05 (200) - very common and well priced
      BFG KDW (300, but many say its TW rating is grossly overstated and more of a 200ish tire -- the DSE guys, Finch, many others run this... and they win)
      Falken RT-615 (200) - been seeing this more lately and getting good reviews http://www.falkentire.com/Tires/Pass...nis-RT-615K-14
      As Brett stated, it comes down to sizing and availability for your setup. Nitto had the exact sizes I wanted, so I went NT-05.
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Oct 2006
      Corona, CA
      Nitto NT05
      Falken 615K
      Michelin PS2's are usually 220
      Bridgestone REO50A are also usually around the same, based on size.
      Check tirerack.com, and search by the sizes you are after, and the UTQG is listed for each one that is available.
      Call me if you want, I can help.
      Scottsdale, AZ
      Quote Originally Posted by Flash68 View Post
      What size front tire are you running? Bummer that the nt-05 only goes up to 315. I've got room for more.
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Nor Cal
      Quote Originally Posted by DriverzInc View Post
      Great tire no doubt.. I had a set for about 10k miles on a previous car. I personally could never justify buying them for the premium they command.
      Quote Originally Posted by Cdog View Post
      Yeah that may steer you in a direction right there. I run the 255/40/17 front. I get some rubbing but I'm pretty low up front.
      What size are your Forgelines front and rear?
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Jul 2010
      Sacramento, CA
      BFG needs to bring back the g-Force T/A KD. That was a great tire, never got why they canceled it.
      On topic here are the tires I know:
      BF Goodrich g-Force T/A KD(200)
      Goodyear Eagle F1 Supercar G 2 (220)
      Goodyear Eagle F1 asymmetric (240)
      Hankook Ventus V12 evo (280) also one of the best wet traction tires out.
      Dunlop Direzza Sport Z1 Star Spec(200)
      Pirelli Pzero (220)
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Scottsdale, AZ
      18x10 front & 18x12 rear
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Nor Cal
      Based on your wheel sizes, I'll bet you end up with the KDWs in 275 and 335.
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Scottsdale, AZ
      Good info thanks. Wonder why they show 300 tw?
      Any BFG reps here to explain this?
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Mantorville, MN
      Quote Originally Posted by SLO_Z28 View Post
      Pirelli Pzero (220)
      The Dunlops are the best tire on that list, but unfortunately a 275 is the widest one they offer.
      Still, I'd take a 275 Dunlop over some of those others in much wider sizes.
      Derek Kiefer,
      Mantorville, MN
      Caledonia, MI
      Kumho Ecsta MX(non run flat) read the reviews on tirerack. I have a set. I don't think you can beat them for the money.
      Jason Mitchell
      1969 Camaro @ Dutchboys
      Jun 2010
      Northern Minnesota
      I talked to a tire rep a while back (ok, maybe 5+ years) and asked him why a 50,000 mile tire from brand x had a tw of 520 and brand y's was 680?
      He told me there was not a industry or government regulated standard on tw. that each company rated the tire as they seen fit off the rest of their product line. so you could compare tires with in brands using tw, but it was not a good tool for comparing different brands.
      does anyone know if there is now a industry standard for tread-ware?
      Jul 2010
      Sacramento, CA
      Quote Originally Posted by Derek69SS View Post
      275 tires keep you in the STU class in SCCA too ;)
      -James
      May 2011
      Wyoming
      Quote Originally Posted by 1red68 View Post
      No, there still is no industry standard.
      Roger
      1967 Camaro, ZZ3/M20, work in progress.
      1957 F100, 4 wheel independent, 4 wheel disc, 32V 4.6, collecting parts.
      2001 Silverado, 11.59at 113 MagnaCharged L33.
      Oct 2005
      Corona, CA
      Here is what UTQG (Uniform Tire Quality Grade, or tread wear) is by definition off something I have here in the shop:
      "The tread-wear grade is a relative figure based of wear of a tire during a 7200-mile-on-vehicle test compared to a reference tire. The higher the number, the longer it will likely last. "300" indicates that the tire should last three times longer that the reference tire which scores 100."
      Based off that, it all depends on what the manufacture determines their 100 rated UTQG tire to be. Leaves a lot open to speculation, if you ask me.
      SoCal
      I've been very happy with my set of Star Specs.
      Quote Originally Posted by JMitch19 View Post
      Well, there's always the Ecsta XS.
      I once wrote a note on BFG's facebook page asking for a more aggressive version of the KDW2. BFG was nice enough to send a response and I received this:
      Brett, thanks for the support with your Mustang and TransAm and since you speak BFG-shorthand, let's delve into your question of grip versus Treadware ratings. The grip comes from a combination of the construction techniques, the internal materials and of course the compound of the tire. How you use the elements is the real key. The g-Force T/A KDW is built in a very unique way that allows us to use two different tread compounds on the tire; on the inner half a compound tuned for wet capability on the outer half one tuned for dry. That outer compound, coupled with the large shoulder blocks and some very interesting manufacturing techniques, allows this tire to be good in the wet and awesome in the dry. To the extent that it's the tire that Samuel Hübinette uses in drifting in his Dodge Challenger, the tire used at Miller Performance Training Center - home of the Ford Racing Mustang Driving School and the tire of choice for the Ultimate Street Car Challenge last year. So treadware ratings have little to do with grip, in the world of BFGoodrich as we can put a little mileage in your pocket too. . . .
      Nevermind that the BFG tire of choice referenced here was actually the R1 from the 2009 OUSCI.
      While it's nice they have confidence in their product, it does bother me that they seem to be resting on their laurels. The KDW is becoming dated and BFG will need to do something if they want to keep competing in the 180-200 treadwear events that they sponsor. For instance, the E-max Challenger has no business outrunning either of the DSE cars at a Goodguys autocross . . . the Advan Neova AD08 had a lot to do with that instance.
      Anyway, I'd still love to see a slightly more aggressive version of the KDW2.
      Treadwear rating is a good rough estimation of grip even if it isn't perfect.
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
      Google = Friend
      http://en.wikipedia.org/wiki/Treadwear_rating
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Mantorville, MN
      Quote Originally Posted by 79-TA View Post
      XS is 180 treadwear, and many of the BFG sponsored events are 200tw limited. :(
      It's unfortunate because the Kumho XS is one of the few really fantastic tires available in "pro touring" sizes... even worse is that even the mediocre tires are abandoning the bigger 17" sizes, so you're left with really crappy tires as the only choice to run on if you have something like a 17x11 wheel.
      Derek Kiefer,
      Mantorville, MN
