View Full Version : Screw in wheel stud torque specs?
BuddyP
05-12-2011, 11:41 AM
What torque for 1/2" screw in wheel studs?
johnny68
05-12-2011, 11:59 AM
i believe its 100 i wouldnt go any more than that
john
Bryce
05-12-2011, 12:01 PM
This sounds high, but the seating torque for a 1/2-20 alloy steal SHCS is 170 foot pounds.
jjordan
05-13-2011, 06:19 AM
I have always seen 1/2" studs/aluminum wheels at75-85 ft lbs.
Yelcamino
05-13-2011, 08:22 AM
Are you looking for the torque to tighten lug nuts or the torque when installing the studs in the axles? If it's the install in the axle torque, then 85 lb/ft is what was recommended by Strange when I assembled my SS axles.
opnwide
05-13-2011, 07:16 PM
I just loctite them and tighten as tight as I can with allen wrench. Those things can't come out, so I just want to make sure I don't have problems pulling the wheels off.
wmhjr
05-14-2011, 06:45 AM
Wilwood says 77ft/lbs for the studs in their 14" brake setup, if that means anything.
rrunner68
05-14-2011, 07:30 AM
+1 for the loctite. It gets annoying as all hell when those things back out.
