View Full Version : Help me find fuel lines
BuddyP
05-08-2011, 07:54 PM
Looking to get my fuel lines squared away. I don't have a tank yet but am running a LS motor. Ran across these below on ebay. I assume I need a return line with using FI. Would 2 of these work? What other options do I have? Would prefer to find a pre-bent line.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400212045139&viewitem=&sspagename=STRK%3AMEWAX%3AIT
Ollie8974
05-09-2011, 04:56 AM
Inline tube can supply pre-bent fuel lines. I am sure there are other vendors as well. Yes, you will need to have a return line.
meenaggie
05-09-2011, 07:36 AM
Most everyone that is running near stock HP (<500HP) LSX uses a C5 corvette fuel fillter / regulator that mounts near the tank. This results in a single line to the front and a short return line. They can be bought at rockauto.com for cheap. There are some LS1's that use a double line to the front but most do not. Do some searches in the LSX forum for more info.
CarlC
05-09-2011, 08:53 AM
Or there's another option.
https://www.pro-touring.com/showthread.php?72309-Track-Ready-Street-Friendly-Fuel-Tanks-From-Rick-s-and-Vaporworx.
https://www.pro-touring.com/showthread.php?77612-You-asked-for-you-got-it.-Three-new-VaporWorx-products.
EFI is a different monster than carburetted applications. 3/8" lines will support the needs of 99% of the EFI swap applications.
Z06vet
05-09-2011, 11:35 AM
This is what I used. About $500. Simple install, stainless, & comes with everything you need. Once you piece everything together you end up spending nearly the same as buying this kit. The guy was very helpful and is almost always available.
http://tubetechweb.com/
