View Full Version : lt1 t56 in 68 camaro need help
brandonkmaddox
05-07-2011, 05:06 PM
I have a t56 out of a 96 camaro and I want to put it in my 68 camaro. I would like to stay with a mechanical clutch if possible. I have a 383sbc in my car is this possible. Someone said i needed to change the input shaft to a later model ls1 and I could use a mechanical clutch if so what bell housing do i need and do need a adapter plate . Could someone help me out with a parts lists.
Samckitt
05-08-2011, 04:03 AM
You should trade me. :-) I have a trans in the garage that was on my LT1, I sold the motor, but still have the trans, going with an LS motor & the LT1 T56 won't work.
brandonkmaddox
05-08-2011, 03:57 PM
my trans is an lt1
Samckitt
05-08-2011, 04:32 PM
Sorry man, don't know what I was thinking when I read it this morning. Someone does make an adapter kit that allows this tranny to work with the old style mechanical setup. But it is going to cost you more than it is worth. Originally I was going to try & go that route when I put the LT1/T56 in the Monte, but I decided to go the mechanical route, made a bracket to mount the hydraulic master cylinder to, & then I used the setup like it was designed for. No problems, works(ed) great.
Glock 18
05-19-2011, 09:58 AM
Brandon - Try Weir Hot Rod Products in CA 800-633-9869 / 707-647-0513 OR Blake at ATS (American Touring Specialties.com) - they make a Camaro conversion package. Hope this helps.
rechin23
05-19-2011, 01:57 PM
Weir hot rod, good guys. I have a 68 Firebird and its a different bell housing. Ive been looking for a long time before I found these guys just a couple of weeks ago.
