shmoov69
04-30-2011, 08:42 PM
I played too hard with it and broke it! I knew the more HP from the bigger turbos would find the weak link, just didn't expect it to happen without slicks and the dragstrip!!
I just got the car back from a friend who put a 6 point cage in it for me, oh and built a fuel tank with baffles and stuff. I changed the tune a little for the new turbos with the 6AL2 and was playing while running around. So I was in second and stabbed it pretty hard and it was spinning pretty bad, but trying to hook and chattering and all. About 5,000 or so there was a big pop and high C'd the motor when it unloaded. So I idle into a parking lot, the motor still running but now it has a little clatter to it, but nothing getting to the rear tires. So after analyzing it for a minute I see that the driveshaft is not turning in any gear. I get a ride to get the trailer and push it on (and rip off the spoiler in process!), take it home and unload it. I pull the valve cover to see what the clatter is and see 1 rocker stud sitting about a half inch higher than the rest.
So I have a junked transmission and need to get screw in studs. I also look down and see a drip coming off the bottom of the master cylinder. SUCK!! Engine and trans needs to come out and worked on, along with a master cyl, new brake pads and shoes (yes, you read correct...SHOES!), front tires and get oil restricters for the turbos. All before the end of the month so I can go to the Run To Music City event to try and tear it up there!!
SUCK!!! I ain't got the extra cash for all this!!
But in all reality, this TH350 trans that I rebuilt has had a good run! About 8 years and LOTS and LOTS of beating!! Now, what kind of suggestions does anyone have to make this thing hold up for the extra HP & TQ I have now? It already had the good TCI clutches and steels in it, but I'm sure it was some hard part failure today.
Also, turns out that a "weak point" for Vortec heads is the press in studs...why hasn't someone told me this before now?!? LOL!
Anyone want to come to Springfield, MO to help wrench?!? LOL:cheers:
