Tom
04-29-2011, 10:12 AM
1967 Chevrolet Camaro: 350cid / 350hp (NOT matching numbers), M-20 4 speed, 12 bolt rear end w/ 3.73 posi.
Jet-Hot coated Hooker headers, Holley 600cfm 4bbl carb, Edelbrock intake.
Admiral Blue (1996 Corvette Grand Sport color) with black interior. Steel cowl induction hood. Hurst shifter. Small, discrete Auto Meter tach mounted on column. AM/FM cassette.
Front disc brakes. 15” Rally wheels w/ BF Goodrich Radial T/As.
Was personal car of body shop technician in Milford, CT who preformed a frame-off restoration in the mid ‘90s. Everything new including full interior – dash, gauges, seats, upholstery, carpets, headliner.
You won’t find one cleaner. $25,000.
I bought this car as the base for a pro-touring build because it was so pristine. I never bought the suspension pieces, but I have available separately the engine, intake and transmission I was going to use:
The engine is a 454 cid SMALL BLOCK. Dart Iron Eagle tall deck block w/ splayed billet 4-bolt mains, Eagle 4340 forged crank, Manley 4340 forged rods, Ross custom forged aluminum pistons, CompCams custom grind cam and valve train, ISKY lifters, Ferrea SS valves., AFR 227 cnc ported aluminum heads. Have ARP hardware and more. All machine work is complete and engine is ready for assembly. Full parts list available. This engine will make 625hp+ on pump gas. All parts brand new. $10,000
The intake is a TWM Induction EFI intake manifold with 8 individual IDA throttle bodies, billet fuel rails, fuel regulator and linkage. New in box. $3,500
The trans is a Tremec TKO 600 5spd complete with short shift kit, cross member, bell housing, aluminum flywheel, clutch and pressure plate and hydraulic release, driveshaft yoke, reverse light switch. New in box. $2,500
I hate to be “that guy” but please, serious inquiries only. This is not a fire sale, just finally admitting that I don’t have time for it. Thanks, Tom. [email protected]
