View Full Version : Some Vehicle Weights
rrunner68
04-25-2011, 05:42 PM
Posted this on Protouringmopar, figured I'd put it up here too. I think The Road Runner is putting me at a bit of a disadvantage, LOL.
As most know, there is always great contention about how much our vehicles weigh. Figured we should have a bit of a post, since I was playing with the scales at work today and had some fun.
1968 Plymouth Road Runner
Fiberglass Hood w/ hinges
383 Aluminuim Heads/Manifold
Full Exhaust
Power Steering
Tremec TKO 600
Dana 60
No Back Seat
6 point cage
No Heater or Radio
WEIGHT: 3550 LBS No Driver/Half tank of gas
68 Dodge Dart Two Door
All Steel
440 w/ Aluminium Manifold
Manual Steering
727
Moser 8 3/4
No back seat
No Heater or Radio
WEIGHT: 3130 LBS No Driver / Half tank of gas
62 Dodge Dart 440 Four Door
All Steel
225 w/2bbl Aluminium Manifold
Manual Steering
PB904
8 3/4
Full Interior
No Deletes
WEIGHT: 3280 LBS No Driver / Full Tank of gas
Henesian
04-25-2011, 05:50 PM
What do you expect? It's a B-body, not an A-body.
rrunner68
04-25-2011, 06:33 PM
LOL, actually, the 62 is a B-body too, lol.
Henesian
04-25-2011, 06:55 PM
Well, whatever. the Roadrunner is just a heavy car.
Motorcitydak
04-25-2011, 10:51 PM
Im not positive on this but Im pretty sure my bare shell of a '68 Charger weighs somewhere around 600 pounds. I want to confirm that tho but if thats true there are a lot of bolt on's there that could be left off making you much faster
CarlC
04-26-2011, 07:12 AM
That's not so bad. Mine is 3600lbs.
Bryce
04-26-2011, 07:18 AM
If mine ever runs it will weigh in at 2700.
Nessumsar
04-26-2011, 07:57 AM
72 Nova
383 SBC Iron/Iron
TH350
Steel everything
3199LB w/no driver, on fumes.
55% front
wmhjr
04-26-2011, 07:58 AM
You think you're at a disadvantage:
'66 Pontiac A-body convertible.
462ci pontiac standard block, aluminum heads, forged everything.
Full 3" exhaust, full interior
Moser 12 bolt, aluminum driveshaft, TKO600
Wilwood brakes, battery relocated, tons of insulation
Power steering, manual brakes
3720lbs but almost 50/50 weight distribution
Randy67
04-26-2011, 11:16 AM
1967 El Camino, all steel, SBC, aluminum heads & water pump, iron block, 2x4 crossram intake, Richmond 5-speed, 3" exhaust, aluminum radiator, manual brakes/steering, no heat or a/c, heavy Soft-8 wheels (39-40 lbs each), 10-bolt, 3-link rear suspension, C5 & LS1 brakes. 3362 lbs with full tank of gas. Never did get chance to weigh it with the V45 wheels, probably closer to 3300 lbs with them.
The Stickman
04-26-2011, 12:25 PM
Hell I am right around 4000lbs with the wagon. It was 4260lbs last time I weighed it. But I have taken a bunch off the nose and it is noticable as the nose has come up a bit. I saved close to 50lbs alone with the aluminum hood and hinges. But all that being said it was a blast to drive on the track. I was really conncerned with how heavy it was but now realize it doesn't matter as much as long as you are having fun with it and the car is balanced in it's handling.
Vegas69
04-26-2011, 09:27 PM
I'm at 3580 before I put in the race belts and cross bar. Disadvantage to some, not all.
cobraguy65
04-29-2011, 05:17 AM
My '66 is just under 3100 lb with TKO 5 spd, 9 inch and centrifical blower.
Kenova
04-29-2011, 05:04 PM
1977 Vega hatchback
Original 2.3 4cyl.
TH 250 automatic
Manual brakes and steering
Heater only (no A/C)
Half tank of gas
With driver (160 lbs.)
2838 lbs.
Too bad it only has 85 hp. (factory rated).
Ken
67zo6Camaro
04-29-2011, 11:20 PM
The Fab53 Camaro aka 67 zo6 Camaro Convt.
Full frame front to back, no top and no side windows
LS6 motor and T56 trans
Coil over front and rear with a 9" and Strange aluminum center section
Some fiberglass parts
3137 lbs with a full tank of gas at 51% nose weight
3310 lbs with a full tank of gas at 50.2% nose weight and my fat ass.
I was also hoping lower, but if I take the gas out (+-14 gal at 8lbs) it is a little closer to my goal. I have a few ideas of losing another 100 lbs and transfering weight to back.
79-TA
04-30-2011, 12:45 AM
https://www.pro-touring.com/showthread.php?55713-What-does-your-car-weigh
Jim Nilsen
05-01-2011, 08:11 AM
3150 lb. and a bit of carpet and a few more braces to go.
can't lose any more that I can find. I need to install the rear swaybar and that will ad some but if I get a hollow bar up front and one for the rear I shouldn't gain any weight.
I'm at 51/49 for the most part but when I get in and the tank is full is probably goes the other way.
I am not so much thinking about less weight these days as I am more power to pull it.
Bryce
05-12-2011, 06:58 AM
Check out this link http://www.ridetech.com/info/coiltech-2/#a14
way to go ridetech!
Matt@BOS
05-13-2011, 02:34 PM
1969 Camaro, full Marquez interior with sound deadening
Anvil inner fenders, AMD aluminum hood.
LS engine
DSE Subframe, Quadralink
Weighed in at Del Mar Goodguys thanks to Rob at No Limit for providing the scales and the RideTech crew for providing the space. The car was about 3420ish lbs. with a half tank of gas.
With a full tank of gas and me in it, it would probably weigh a tad over 3600 lbs with 48/52 front rear distribution. The cross weight was horrible though, and I'd like to remeasure because I can't figure out why it would be so different.
Matt
Ron.in.SoCal
05-13-2011, 03:15 PM
I'm a little surprised you car is lighter on the nose Matt. Good job Sir!
Yelcamino
05-13-2011, 03:53 PM
You got some lightweights there! My Chevelle is 3700 lbs and my El Camino is 4070 lbs!
Randy67
05-16-2011, 06:33 AM
I finally weighed my 2000 Dakota R/T, total was 4140 lbs with approx 2600+ lbs on the front alone. No wonder it tends to push the front tires, 275/50/17 tires aren't big/wide enough.
