View Full Version : Correct washer for solid UCA bushings?
First Bird
04-25-2011, 07:05 AM
I have searched and searched. Nothing. Hope someone can help me.
Stock UCA
Moog offset cross shaft
VSE steel bushings with nyliners
Washers that came with solid bushings are serrated and hold smaller inner bushings against the shaft while allowing outer bushings/UCA to rotate. The 5/8" conical washer that came with the offset shaft is for rubber bushings. I could drill old washers to 5/8" but that would remove both the serrations and the taper that holds the inner bushings. Anyone know what I should use? Thanks in advance.
