View Full Version : QA1, FAST, Lokar and GM parts
scherp69
04-24-2011, 05:22 PM
Time to get rid of some stuff to make money for new parts.
QA1 coil overs, currently on a 68 Acadian (exact same as a Nova). All four have been installed on the car, but never used. The car is still in the build process. Fronts are part # HAL-DR4855P. Single adjustable. Retail at $159.95 each at Summit. The are a universal spring and are a true coil over. They are currently on a Speed Tech subframe. Springs: I have a set for a LS motor, part # 9-450. Retail at $40 each. I also have a set of sbc springs, but I think they are an inch too long.
https://static1.pt-content.com/images/pt/2009/04/PICT00038-1.jpg
Rears are part # HAL-DR5855P. Single adjustable. Retail at $159.95 each at Summit. They are also a universal spring and area true coil over. They are currently on a Prodigy Bar / Air Bar rear set up. Springs are part # 12-250. They retail at $40 each.
https://static1.pt-content.com/images/pt/2009/02/PICT00091-1.jpg
I'll take $600 shipped for the set. I would rather not separate, but if the set's not moving, I will consider it. SOLD
I've also decided to sell my FAST 102mm LSXR intake. It's been bolted on and never used. The only 'flaw' is that I wanted to see how easy it would be to sand it down smooth so there is a smooth part on top where I sanded it. I will also include the manifold seals which I bought separately.
EDIT: The intake is for a LS3/L92. It is part # 146102. I have all the bolts and hardware that came with it. As stated above, it also includes the manifold gaskets which do not come with the intake when you buy it. I bought these extra. They are about $25 for the set. I even still have the original box for it.
Here's a pic of in on the motor. You can see where I started to sand it. There's a bit of yellow on it from the sandpaper. If someone is interested in the intake, I will make sure that the yellow comes off. If the plan is to sand it down, then it won't really matter.
https://static1.pt-content.com/images/pt/2011/01/P1000797-1.jpg
These are going for $950 at Summit and Jegs. I'll take $700 shipped. SOLD
Lokar universal throttle cable. New still in the package. $42.95 at Summit.
http://www.summitracing.com/parts/LOK-TC-1000HT/
I'll take $35 shipped. SOLD
GM replacement wiper motor. Part number 40140. Fits several cars including Camaro, Chevelle, Nova and many others. Also have a AC Delco washer pump. GM part # 4919332. Fits 64-68 Nova and 67-68 Camaro. Both new and still in the box.
Here's the motor: http://www.summitracing.com/parts/AAZ-40-140/Application/?prefilter=1
Here's a picture that I found of the washer pump from Rock Auto. http://www.rockauto.com/dbphp/x,catalog,308,partnum,4919332,d,acdelco_4919332.ht ml
Together they retail for $140. I'll take $120 shipped for both. SOLD
I start back to work it the morning so I don't get back to you right away, don't panic. I will get back to you hopefully that day or the next. PM me if interested.
scherp69
04-25-2011, 01:16 PM
I had a request on another forum for some close up pics of the sanded area on the intake. Here's they are. I also got the yellow cleaned off. Now it just has a bit of a lighter gray where it was sanded. I took a few pics to try and give the best view of it.
https://static1.pt-content.com/images/pt/2011/04/P1000954-1.jpg
https://static1.pt-content.com/images/pt/2011/04/P1000953-1.jpg
https://static1.pt-content.com/images/pt/2011/04/P1000952-1.jpg
https://static1.pt-content.com/images/pt/2011/04/P1000950-1.jpg
Here's one in case you could see where the sanding was done
https://static1.pt-content.com/images/pt/2011/04/P1000950red-1.jpg
scherp69
04-27-2011, 09:36 AM
Intake and wiper parts are sold.
scherp69
04-30-2011, 02:01 PM
Everything has sold. Thanks for looking.
