View Full Version : Oldsmobile Offenhauser Valve Cover Install
dipren443
04-24-2011, 07:28 AM
Fellas,
I am trying to install the Offy VC's I bought for my dad's Cutlass. It is a fight to the death.
The passenger VC was machined to accept a thread in PCV valve, that was a piece of cake. Clamp on breather installed on the drivers side. When it came time to reinstall the power steering pump, it isn't even close to clearing. The rear bracket could easily be modified to work with a little bit of steel plate and some welding. The front on the other hand... I would need to cut a bit of the front right near one of the mounting bosses. I am tempted to just make the cut and see if the belt has any wobble. My other options seem to be to fab my own bracket or buy Mondello's piece at $500...
So who else wants a bracket to mount a Type II GM PS pump to an Oldsmobile? :P If there is a need, I would consider doing the R&D to make one.
https://static1.pt-content.com/images/pt/2011/04/Orlando2011042400106-1.jpg
The Stickman
04-28-2011, 04:56 PM
Nick how much does your dad want to keep it stock?
dipren443
04-29-2011, 12:24 PM
Not necessarily Neil. What do you have in mind? Also, we did mod the front bracket to clear. He is shipping the rear to me and I will make the necessary mods. If it doesn't work out in the long run, we will be looking for the next fix. Give me whatever ideas ya got.
Thanks!
The Stickman
04-29-2011, 12:26 PM
I would say switch to a later model set up with newer power steering pump. Do you have a pic of his pulley set up?
Chicken Coupe
04-29-2011, 09:00 PM
Might want to check with Alan Grove Products to see if they have a solution.
http://www.alangrovecomponents.com/index.htm
The Stickman
04-30-2011, 07:38 AM
I don't see anything on there for Oldsmobiles.
dipren443
04-30-2011, 10:47 AM
Neil,
That was my thought. What I am unsure is interchangeability with Olds drive setups. What other years could be used as donors?
The Stickman
04-30-2011, 01:41 PM
Neil,
Olds are their own set ups. But there are a bunch of different ones. Olds was pretty goofy on them. I might actually have a older Olds PS pump without the O rings on the hoses but later than that PS Pump you have. I should also have an upper altenator mount. But you would need the proper pullies which is why I asked. if he has 3 groove crank and water pump pullies it would be ok.
dipren443
04-30-2011, 01:43 PM
Neil,
I am already back in PA. I will have my Dad take some pics and email them to me. Stay tuned!
Concept One Pulleys
05-06-2011, 10:17 AM
Nick--
Drop us a line if you're having a hard time with your pulley setup. We have quite a few resources for finding hard to get parts, and do a lot of custom work ourselves. If you need help, give us a shout @ 1-877-337-0688.
Kevin
Concept One Pulleys
Made in the USA
Serpentine Pulleys (http://www.c1pulleys.com)
The Stickman
05-06-2011, 10:21 AM
Nick--
Kevin
Concept One Pulleys
Made in the USA
How about a true serpentine belt system for Olds engines?
jocko124
05-06-2011, 11:10 AM
I have a type II on my 66 Cutlass and can hook you up with the guy who made me the bracket--he made extras!!!
dipren443
05-06-2011, 12:33 PM
Lee,
I would love to have that contact info.
Nick
jocko124
05-06-2011, 01:09 PM
Bill Trovato.......BTR Performance 585-303-7560. He's located in Rochester, NY. He rebuilt my engine (and recently fabricated a bracket for me) and I highly recommend him. Very honest & knowledgeable guy. BTRPERFORMANCE.COM.
jocko124
05-06-2011, 01:56 PM
By the way, love those Offy valve covers.................I have a set myself!!
Concept One Pulleys
08-04-2011, 05:32 AM
To The Stickman--
Call us at the shop, toll free 1-877-337-0688. Ask for Kevin.
We'll take care of you!
Regards,
C1 Pulleys
Chevy Engine Parts (http://c1pulleys.com/chevy-engine-parts.html)
therobski
08-07-2011, 10:32 AM
Yes indeed you need to go with a later model P/S setup like I did on my 67. I pulled one off a 72 Cutlass. Bought a rebuilt pump from Napa. Make sure if you get one off a donor motor get the donut type bolt spacers that go between the brackets and the block other wise you will have alignment issues. But it's an easy swap. The lines will bolt right up to the box. I used a non-A/C alternator bracket like you already have. I just went out to the shop and took these pictures for you, it's really easy.
https://static1.pt-content.com/images/pt/2011/08/IMG_1014-1.jpg
https://static1.pt-content.com/images/pt/2011/08/IMG_1015-1.jpg
https://static1.pt-content.com/images/pt/2011/08/IMG_1016-1.jpg
https://static1.pt-content.com/images/pt/2011/08/IMG_1013-1.jpg
