View Full Version : trans cooler or not?
Ishmael
04-20-2011, 08:28 AM
I've seen this debate go both ways - with a 4l65 with a mild convertor, should you use an in tank cooler or an external cooler?
thanks
Scott
Poorhousenext
04-20-2011, 12:13 PM
I've this debate go both ways - with a 4l65 with a mild convertor, should you use an in tank cooler or an external cooler?
thanks
Scott
If you are going to beat on the transmission read below info and make your decision as to whats best for your transmission. Information comes from forum like this were vendors for transmissions and stalled converters answered your question, or posted general transmission information on most commonly asked questions.
Do I really need a tranny cooler with stalled converter?
Yes. As a by product of the stalling effect, more heat is created. This heat is damaging to the tranny and the way to deal with this is to get another tranny cooler.
Do I need to have a cooler with my converter or transmission?
The answer to this question is yes and we furnish every unit with one. While not having a cooler is not going to cause your transmission to die tomorrow, heat will kill it in the long run by hardening seals and gaskets. Having a stall converter will only compound this problem. Installing a cooler is just a good idea.
Tips, Hints, For Transmission Cooler installations ________________________________________
Many of you add aftermarket coolers to your cars and this is allways a good idea. Here are some hints.
1-Allways mount the cooler in a place that has good air flow and if mounting in front of the radiator always make sure the fin's in the cooler are parallel with the fin's in the radiator to avoid restricting air flow to the radiator. If you must place the cooler in and area with little air flow a FAN is a must.
2-When Installing coolers make sure lines are clear of anything that can rub them and always use line that’s approved for transmission/hydraulic fluid. Fuel line will not work and will break down in transmission fluid.
3-By passing the radiator is the way I prefer a cooler be set up. Generally the transmission will run cooler this way and additionally this may take some of the load off the radiators job of cooling the engine.
4-When hooking up multiple coolers several things should be noted. The cooler itself is a restriction of flow and this restriction while not a problem for the cooling or lube to the trans can cause excessive pressure inside the converter. This can force the converter against the flex plate more so than normal and cause wear to the engine thrust bearing. A stopped up or severely restricted cooler or cooler lines can do the same. So when installing more than one cooler its advised to put them in parallel with each other, This means one line from the trans is split with a Y and one line run to each cooler then out of each and into a Y back to a single line running to the trans. This will assure adequate cooling while reducing the wear to the engine thrust bearing. Always use line that’s at least as large as the inlets in the cooler, Avoid extreme twist or turns in them particularly with rubber lines.
5-Type and brands of coolers; I really have no preference here as far as brand. From my experience and expensive brand name or a generic unit appear to do the same job. I have found the stacked plate (Flat tube) Types when measured inlet to outlet temp drop tend to be more efficient in the same dimensional sizes with a greater temperature drop. I did a test once with two coolers in parallel one round tube and one flat with a laser thermometer to determine this.
6-This is not specifically about a cooler but about cooling. Always be sure that the metal lines coming from the transmission under car do not contact the headers or exhaust. I once had a car where the transmission temps would sky rocket when the car was being run hard and couldn’t understand why. I after some looking around found that the cooler lines in and out were pinned against the headers. This would super heat the fluid when the headers got hot. Moved them away and the problem was solved, So always keep trans cooler lines factory or otherwise as far away from the exhaust as possible.
7-Trans temps- This question gets ask a lot. What’s TOO HOT? Well ideally you want you average temp to stay under 190 degrees however I would not get to concerned till the temps get at and or over 230 degrees. Heat can damage a trans but with the exception of extreme heat 250 or higher this damage is a long term killer by breaking down fluid and causing rubber seals to harden and break.
8-Never use your cooler lines to remove fluid from your transmission by starting the engine or in and attempt to flush by catching fluid in a pan while adding fluid to the dipstick. When this is done no lube is being sent to the planets and bushings and they can go dry and melt down very quickly destroying or significantly shortening the life of your transmission.
9-It is advisable to fully and properly flush a cooler especially when a converter failure is involved. Where a transmission internal failure is unlikely to put debris in the cooler since all fluid coming from transmission must travel through the trans filter. The fluid coming from the Pump or converter does not and any debris from these will certainly end up in the cooler. Its always a good idea to power flush a cooler or replace after a failure but is particularly important in the case of this type failure. Anything that’s in your cooler or lines will end up in your Valve Body, Bushings and Planets. A cooler cannot be properly cleaned simply by blowing air through it. A can of cooler flush which most transmission shops and or transmission parts suppliers should have followed by a blow out with air is the correct way to do it.
10-When installing rubber cooler lines to metal lines it’s a good idea to put a small flair at the end of the metal line. Not too big because you will tear the line on the inside during install. Then place a clamp just ahead of the flair. Also roughening up the outer surface of the metal line with very coarse sand paper in area where clamp will ride will help assure a good seal and reduce the possibility of blow off. Never over tighten clamps to the point of the rubber oozing through or being cut this will cause a failure too.
11-Temp sending units- The best place for these is in the pan since that will give the best average temperature which is what’s important, using the pressure port is ok however you will show temps 10 to 20 degrees higher average than you would in the pan. I do not suggest placing temp senders in either the inlet or outlet from the cooler as they will increase cooler restriction and increase the odds of a leak.
Automatic Transmissions
OIL TEMPERATURE MEASURED AT CONVERTER OUTLET TO COOLER:
300° F=
The maximum allowable temperature. This is the recommended place to install a temperature gauge or sensor. Do not allow the converter outlet temperature to exceed 300° F. The temperature at this location will vary significantly because of load, hill climbing, etceteras. If the temperature reaches 300° F, reduce throttle. To lower transmission temperature with transmission in neutral, run the engine at 1,200 RPM for at least 2 - 3 minutes while keeping a close check for signs of engine overheating. A transmission in a heavy throttle, stall condition (a typical situation is rocking a vehicle stuck in mud, sand, or snow), may increase temperature at a rate of 1° degree per second of stall.
OIL TEMPERATURE MEASURED AT OIL PAN OR SUMP:
150° F=
The minimum operating temperature. Note: It is possible in low ambient temperatures to overcool the transmission with auxiliary oil to air coolers. Oil to water coolers in standard factory radiators will normally not overcool a transmission.
175-200° F=
Normal pan oil temperature operating range.
275° F=
Maximum allowable oil pan temperature for short durations during long hill climbs.
300° F=
Damage occurs to internal transmission parts, including warpage of metal parts, degradation of clutches, and melting of seals. Transmission oil oxidizes, (forming varnish-like substances causing further clutch slippage and compounding heat build up) and transmission oil life is extremely short.
https://static1.pt-content.com/images/pt/2011/04/heatchrt-1.jpg
Ishmael
04-20-2011, 12:27 PM
Thanks. I searched "Trans cooler or not" - obviously the wrong terms.
What I read in one of these quotes contradicts what I was told by a trans shop today. One of the quotes said it was preferable to bypass the rad and go straight to the cooler. I was told today to go into the rad then from the rad to the cooler and then back to the trans. If cooler is better would the extra cooling brought on by the rad be ofset by the pressure it would take?
Poorhousenext
04-20-2011, 02:13 PM
That question comes up often. I think the response is correct from either based on primary use as well as performance application usage.
If it's a local Transmission Shop I'm sure they think daily driving & towing stock stall applications vs Transmission Vendors that cater to performance enthusiasts with stalled converts who expect trans to be operated where fluid temp can quickly go to around 275-300 degs during a race and then need to be cooled down quickly to prevent fluid breakdown.
If cooler is better would the extra cooling brought on by the rad be offset by the pressure it would take?
I believe another response also made mention that why tax the radiator that is trying to keep the engine as cool as possible for both performance and longevity with having to help cool down transmission fluid that is seeing hotter than normal temps because you pushing both engine and transmission to or near their limits.
Question may be, "Does running fluid through the radiator before routing it through external cooler provide extra cooling?"
Radiator can only try to cool the trans fluid down to around the same temp as water. Just means the cooler doesn't have to remove as much heat.
The Performance transmission vendors depend on their transmission holding up and they want fluid cool to prolong it's life and keep the customer happy.
If you route the cooling lines as below, then you get a mix of temperatures from both sources, and likely less pressure on converter. Fluid temp probably will be hotter than if just routed through a cooler.
If your going to be abusing engine and tranny participating in Pro-Touring style events, I'd go separate. Runs can last longer than 9-14 seconds straight line racing runs, so help the radiator do it's normal job by letting tranny cooler do it's.
Ishmael
04-20-2011, 02:38 PM
THE TECH
04-21-2011, 08:16 AM
Great info!!
moreHP
04-21-2011, 08:22 AM
Great post poorhousenext. Lots of good info to file away there.
