Results 1 to 20 of 21
06-15-2005 #1
#*$*#@@# Brake lines keep slipping out of my flaring clamp!
So i am trying to do some double flares on regular brake lines. I cut the brake line smooth it flat and then chamfer the outside and inside, I then put it in the clamp and use the black piece to guage the height, then i put the black piece with the nipple going into the inside of the line. THen i put the assembly in a vice and tighten the hell out of it, then i put the flaring tool onto the clamp and tighten the living day lights out of it. then i proceed to do the first step of flaring, but the damn brake line keeps slipping out of the clamp!! I have a ridgid 345 tool which some people like. I have super tighten both my work vise and the flaring clamp and it still slips out. what is going on here??
06-15-2005 #2
- Join Date
- Dec 2003
- Location
- lost
- Posts
- 2,607
Regular regular or regular stainless?
06-15-2005 #3
Pro-Touring Veteran
- Join Date
- Aug 2004
- Location
- NY
- Posts
- 1,070
I think that is the one I have? Does the top part of the tool actually clamp the tube holder from the side or does it only slide over it and push down creating flare. If it is the later go to Home Depot and get the other. Also lube that little die and DO NOT tighten down or it will get stuck in the tube and can break off. Hyd unit is way to go.
06-15-2005 #4
Banned
- Join Date
- Nov 2003
- Location
- Maine
- Posts
- 1,076
yody
sometimes the grooves in the clamp that holds the line fill up with metal from the brake lines, try using a pick or wire brush to clean them out some, it should work
jake
06-15-2005 #5it was brand new, clamps from the side, screw down to flare from the top. Grooves are clean. Flaring regular old brake line, zinc coated.
06-15-2005 #6
