View Full Version : windshield, use the rubber seal or glue them in?
capri v8 driver
04-17-2011, 12:15 PM
i have a 65 mustang, witch uses rubber seals. the first rubbers seals leaked very badly, so i replace the old ones for new ones. and they leaked as well. so i got the windows out again and reinstalled them with alote off sealer. but they keep leaking. so i replaced the rubber gaskets for ford licented seals. same story, they leaked, so i brought the car to a car window specialist, but still they leak.
so now i have the idea to glue them in, insteed off using a rubber seal.
what do you think off that idea?
nekkidhillbilly
04-17-2011, 12:47 PM
urathaned in are how all new cars are i dont see and issue
NOT A TA
04-17-2011, 01:01 PM
Are you positive it's the window leaking and not the cowl?
capri v8 driver
04-17-2011, 11:05 PM
i already closed the cowl to rule that out. both the front and rear windows leak.
cobraguy65
04-20-2011, 06:07 AM
I have the same problem on my '66 mustang. We glued them in on a friends '64 galaxie with no issues.
monteboy84
04-22-2011, 12:12 PM
Gluing them in helps strengthen the structure of the car too.
-matt
nekkidhillbilly
04-24-2011, 04:26 PM
rope seal bs is bad idea on windsheild anyhow slam on the brakes sob comes out
capri v8 driver
05-06-2011, 04:03 AM
thanks, i will glue them and uses the top part from the rubber seal to close the gap between the window and stainless trim.
