View Full Version : What Style Lug Nuts for BMW wheels
analyte
04-12-2011, 07:24 PM
Since I needed new axles/hubs for my disc brake conversion, I had them drilled with both a 5x120 for use now and a 5x4.75 in case I change wheels in the future. I have also the proper sized hubcentric rings to center the wheels on the hub.
I'll be using 12x1.5mm studs and I need help choosing what type of lug nuts I need for my BBS RS-GT wheels. From my research, I've read that conical lug nuts are recommended for these wheels.
The only problem is I've found both 45deg conical and 60deg conical lugs, and I don't know which one I need. Any help is appreciated by those in the know.
Kerry
analyte
04-15-2011, 09:01 PM
Just in case anyone else needs to know, I called BBS today and found out 60 degree conical is what they say to use with there wheels.
Kerry
monteboy84
04-18-2011, 05:58 AM
Yup that's what I'm using on mine. I actually like using stock take-off lugnuts from ebay, they're not fancy, but they're zinc-plated, high-quality, and really cheap.
-matt
DriverzInc
04-21-2011, 06:50 PM
Yes, 60 degree conical is correct for a BBS wheel.
analyte
04-21-2011, 07:07 PM
Thanks Jon!!
How the little girl doing?
Kerry
