obengston
04-11-2011, 05:54 PM
I just recently installed a nitrous system.
Elderbrock RPM 100-250 shot system.
I added the following:
1. Digital RPM window switch
2. MSD mechanical retard switch (can pull timing before use)
3. Lean shut down switch (detects if going lean then shuts system off)
4. remote bottle opener
5. heater with pressure switch
6. digital tank pressure gauge (so I can see the pressure while driving)
7. wot switch
I do have a digital AEM A/F gauge
I put a "t" -an fitting before fuel log on carb and run line to fuel solenoid. I have the new holley mechanical (flows 175gph) with out needing a regulator.
I have 8an gas line from tank to fuel log.
So i will use the lowest pills 1st (100 shot). My question is it better to do this on a dyno or on the track (test) first.
I'm thinking dyno 1st so I can do the NA pull 1st then on the juice. Any comments or suggestions...
Engine is 383 forged internals, Dart Pro 1 215 worked heads. AED 750 Carb. Custom ground cam, 1 3/4 stepped to 1 7/7 headers, 3" exhaust, MSD ignition system, compression 10-8
Plugs AR3933 should I change these??
7. wot switch
