    Results 1 to 7 of 7
      Feb 2010
      Bay Area California
      will a bmw wheel fit a 69 camaro
      I need some rollers to move the car around and my friend has a set of bmw wheels that i can have, but i dont know if they will fit.
      the bolt pattern for a bmw is 5 x 120
      When i google it looks like third gen camaros can fit bmws so does that mean they will fit a 69?
      1969 Camaro
      LSX 454
      Boze Autocross 18x9 front 19X10 rear
      Marquez full interior
      Recaro seats
      TCI front clip
      TCI rear torque arm suspension
      Currie F9 9" rear
      Willwood 6 piston calipers front
      Willwood 4 piston calipers rear
      Ididtit push button start steering column
      E-Stopp electronic e-brake
      Jan 2010
      Elk River, MN
      Depends what the backspacing is, they will bolt up but the bolt pattern is off by .65mm, so you really should run adapters for highway use, but for just rolling around the shop they should be fine.
      -matt
      Mountain Springs, Texas
      Older 5 and 7 series staggered sets (8.5 and 10) will usually bolt right on with the correct backspacing but double check to be sure. If you decide to run them on the road you will need hubcentric rings. At least this has worked for me.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jan 2010
      Delaware
      Quote Originally Posted by dhutton View Post
      Agreed. I bought a set of Ronal Wheels for my 73 TA. This subject has been brought up several times quite recently, and farther back too. Do a search in here and double check BSing for your wheels....and your application. Often no two cars are exactly the same.
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
      Sep 2009
      Issaquah, Wa
      I've been running BMW wheels (Forgeline) on my Camaro for years with no problems. Never been on the track with them, but lots of miles on the highway. I installed new studs when I initially put them on and there doesn't seem to be any signs of stress. I know there are a lot of varying opinions on this though.
      Feb 2010
      Bay Area California
      Thanks to all for the quick responses, looks like the camaro is going to get some new rollers.
      1969 Camaro
      LSX 454
      Recaro seats
      TCI front clip
      Currie F9 9" rear
      Jan 2010
      Elk River, MN
      If you do need adapters, I'm running ones from http://www.motorsport-tech.com/, they're really nice quality and great to deal with.
      -matt
