View Full Version : Has anyone had problems with Entropy aluminum radiators????
speED
03-19-2011, 01:31 PM
67 Camaro, 454, 600HP. Just installed Entropy aluminum radiator with dual fans(3000 CFM) over the winter. I'm running a constant 200 - 205 degrees F while driving(both highway & idle) in 60 degree weather. Prior to this set-up, I had a 4 core copper radiator with a factory fan and shroud which would run these temperatures only on 90 degree summer days. Starting to feel as though I wasted my money!!!!!!!!!!
ProdigyCustoms
03-20-2011, 09:12 AM
I quite selling them because of persistent overheating issues.
3000 CFMs? What fans did it come with? It would need high performance 12s to get 2900 CFM, and I have never seen dual 13s on one of their radiatorspost a pic.
speED
03-20-2011, 12:43 PM
This is part of their ad on Amazon "This core is 2 inches wider than the standard 22-1/2 inch wide core small block radiator and employs 18 fins per inch versus 14 on most everybody else's small block and big block radiator. This bolts in directly - no holes to drill or a trip to the hardware store for a parts hunt. Also include is the aluminum shroud with high powered 11.5" paddle blade fans (not the cheap lower powered fans) delivering a TRUE 3000 CFM. Together, they pull 35-40 amps (check the current rating on the cheapy fans that claim to pull high CFM). This unit features all aluminum construction, a nocklok forced nitrogen brazed core, two rows of 1.00" cooling tubes, precision TIG welded construction through out, strong 6061 hose connections, brass drain **** and overflow connections."
I believe when I bought it off of E-bay they also claimed a few horsepower #'s which made me feel comfortable. I know I also checked the forum before purchasing and I thought everyone who used them was happy. Obviously I tried to save a few bucks and I'm going to pay twice for it, what I need to focus on is fixing the situation. Frank, what do you have to fit my car? Should I just give you a call - would that be easier?
ProdigyCustoms
03-20-2011, 03:29 PM
I cannot find any 11.5 fans. They are most likely 11s which a pair will pull 2600 or so. Which in many cases is enough but for a water heater big block, prolly not.
Our standard F body set up runs dual 13s and pulls 3490. I am building one now for a 598CI water heater with dual 16s pulling 4800CFM. It requires relocating the battery to the trunk, opening the core opeing in the core support, and some redrilling. I will do a little install feature on it when we do it.
Our set ups are a lot more expensive the what you have, but everything about them is a much higher level of components. Your looking at $900 or so for radiator, fans and built in shroud.
speED
03-23-2011, 10:50 AM
Update:
The entropy shroud does not allow enough airflow while cruising. I removed the shroud and the temp dropped 45 degrees.
dhutton
03-26-2011, 06:15 AM
Just a thought but did you reverse the fan connections? I think that might cause some of what you are seeing...
speED
03-26-2011, 09:22 AM
I checked the fan direction immediately after installing. In fact, I also purchased there wiring harness.
speED
03-26-2011, 09:34 AM
Update: I had some difficulty on my end contacting Entropy radiators. Now with them being aware of my situation they are also helping in providing a solution. Seeing that other members of the forum have not responded with negative comments I do not want to give anyone the wrong opinion about their product.
speED
03-30-2011, 07:09 AM
Update: The fan wiring on 1 harness was incorrect. Whoever provides the wiring harness for Entropy accidently confused the 2 wires on 1 of the weather pack connectors. When I checked the fan rotation I must have only checked the one fan. The harness is also covered with wire loom so visually I did not see when plugging the weather packs together. With shroud and fans installed engine temp is at 175 in 50 degree weather while running down the highway. I'm still convinced the shroud obstructs alot of air flow on the highway, since without it i was running at 155-160. At idle the fans come on at 195 and cool engine down to 170-175.
poboyracin
04-03-2011, 03:20 PM
I've been researching this a lot the last couple days and I am also convinced that the aluminum shrouds inhibit air flow at speed. Not on just Entropy's shrouds but all of them that use 11" or so fans. Maybe the bigger fans won't have this problem. Many OEM electric fan shrouds use rubber flaps to let the air pass through the core at cruise. The flaps are closed at idle and low speeds though. Spal also uses them on their dual 11" fan combo.
I'm about to buy the Entropy kit with electric fans and I will try it first without flaps and then I will add flaps across the top and bottom to see if it makes a difference. Spal sells the flaps here http://www.spalusa.com/store/main.aspx?p=itemdetail&item=30130012
speED
04-05-2011, 06:41 AM
poboyracin,
The quality of the Entropy radiator is excellent. In fact, Tony(owner) mentioned to me that for my application he even has one with 1.25 in. tubes. You may want to call him or email first. Thanks for the link for the flaps, I'm actually in the process of fabricating my own design flapper. My car is not a trailer queen but I cannot get myself to put that ugly flap(my opinion) on the shroud. I have a pretty good design which I will post when done.
poboyracin
04-05-2011, 01:00 PM
I'd be interested to see your flap design. I agree the rubber flaps aren't pretty but it's simple.
speED
04-06-2011, 04:47 AM
I'll post pics when done.
Z06vet
04-08-2011, 07:39 AM
I am just finishing up my build & have been driving around on short trips both highway & stop & go. We have had temps 70-85 in the last 2 weeks. Fan 1 comes on at 185 and fan 2 at 195. I have not gone over 185/190 at all. Not much to go on, but we'll see what happens when the AC is up & running, 95 degrees, ac on, in traffic. I have their LS1 rad/fan setup. My computer is controlling the fans. If I have it wired correctly, the computer should turn on fan 2 as soon as the AC is turned on.
68sixspeed
04-08-2011, 10:30 AM
Regarding the flaps, I don't think they are needed. I have a 23" (big block sized) Afco aluminum radiator, two 1" rows in it with their full shroud which has a single ~2000cfm fan, Last few years I ran a 195 thermostat, it would run right on that, maybe 205 in traffic in the summer. This year I dropped back to the 180 thermostat, just ran the RTTS track day and granted it was cool but it never went over 185 at speed on the track, no trouble during autocross etc either. That dual fan setup looks nice, I think you'd be fine with that w/o flaps.
speED
04-10-2011, 05:07 PM
68sixspeed,
The flaps may not be needed. I just know that the shroud is a 50% restriction and it runs 10-15 degrees cooler without it. I would prefer the engine to run as cool as possible and fine tune the temperature range based on thermostat selection.
speED
04-23-2011, 05:03 AM
Update!
I performed a test yesterday in 50 degree weather. I tested the car three different times:
Test 1: full shroud - engine ran at 175 degrees on the highway.
Test 2: drilled 10 2" holes into shroud, 5 holes above fans, 5 holes below fans - engine ran just below 170, approximately 168.
Test 3: no shroud - engine ran at 145 degrees.
These full shrouds are really reducing the radiators cooling capacity according to my tests!!
poboyracin
05-21-2011, 10:45 PM
If mine will stay at 180 all the time, I'm good. I don't want to run under that.
speED
07-09-2011, 06:52 PM
Update!
Cooling system is working great. Entropy replaced my 2-1" core radiator with a 2-1.25 core. I also fabricated a new fan shroud for more airflow. In 88* weather, driving for 1 hour, engine temp fluctuated between 175* - 190*.
Chad-1stGen
07-09-2011, 07:23 PM
Update!
Sounds like Entropy stood by their product.
Interesting on the fan tests. Thought something doesnt make sense. Why are you seeing such cold temps with no shroud. Are you not running a thermostat? If you are running a thermostat it should be capable of keeping the engine at temp.
speED
07-10-2011, 05:41 PM
No thermostat, I took it out to have a good comparison between changes. Figured the modification that worked best would obviously make the car run the coolest. I will be putting a 160* thermostat in next week to help control temp during cooler weather.
tonykim
07-11-2011, 07:18 PM
with the really high fin density and the aluminum shroud on the back side of the radiator my guess is that at cruise a lot of air will try to entirely bypass the cooling system because the airside restriction is pretty large in comparison to air paths around the radiator or from the grill and out the bottom of the radiator. This becomes further compounded by having a deeper radiator core. Some OEMs put ram air flaps in the fan shrouds that simply open at speed to take advantage of ram air cooling without constantly depending on the fans to pull air through a higher restriction radiator core.
Bmf5150
10-20-2011, 03:42 PM
U have any pics of your modded fan shroud??i might do the same!!
Havasuhound
09-16-2012, 10:22 AM
The Entropy radiator sucks! It is pretty, but a big let down and a big waste of money. I cannot sell it it to a buddy or anyone in good conscience as it does not cool.
diesel25lrs
09-17-2012, 09:41 AM
I have to say that I'm very happy with my Entropy after this weekend! 1st wknd driving the car btw...I was at RTTH8 thrashing my car all day in about 85*, stuck in 90 minutes of stop and go traffic on DP Parkway and not once did I go over 190*.
I also did notice that one of the wires was in the wrong loom from what the directions said-confused me- called Tony right away and he talked me thru it over the phone! Great product!
69cutlassrkt
09-17-2012, 10:45 AM
I made of video of one fan runnning. I think the entropy radiator and fans work fine. I paid 700-750 for it I do not think it is worth that much money, but I think you could get it much cheaper than that now. Been running this radiator for 3yrs I think(25,000miles on it).
http://www.youtube.com/watch?v=WtP1-mrGXcI&feature=youtu.be
Z06vet
09-17-2012, 11:06 AM
I have had no problems with mine either. Have over 7K miles, part of 2011 power tour, & just like diesel25 was at RTTH8 this past weekend and never went over 190. Plus I drove it 500 miles each way to pigeon forge, and thrashed on it thru the blue ridge parkway after the autocross on sat. I'd buy another without hesitation.
Z06vet
09-17-2012, 11:17 AM
By the way Josh, was great meeting you. We left a little early sat afternoon so we could hit the blue ridge parkway. My buddy had to work sunday night so we headed back sunday morning. Hope to catch up with you again at another event. Scott
fast400
06-12-2014, 06:56 AM
I can only concur! Worst customer service ever! Mine started leaking, and they simply said it was galvanic corrosion...which it didn't have. It was grounded and clean as a whistle inside. Took them 2 months and several phone calls to come up with that lame answer. BUYER BEWARE!!
69cutlassrkt
06-12-2014, 08:27 PM
I had a fan go out last year. They sent me a new one and after I got it I sent the old one back, it had a lifetime warranty. It wasn't too much of a hassle. The way the fan mounts on the shroud is dumb though cause it's just nuts and bolts. It sure would be a lot easier if the nuts were tack welded on when changing out a fan. I would be mad though if my radiator had started leaking.
Justin@EntropyRad
01-12-2015, 01:20 PM
Just checking in on this thread to see if anyone had any updates?
Justin aka "Jimmy New Guy" at Entropy
badazz81z28
01-26-2015, 02:41 PM
Well, these post are concerning granted I'm ready to buy. I have a radiator with a rudimentary fan install. I want something that looks professional/OEM like,
icemanrd19
02-28-2015, 02:51 PM
Yes justin why should i chose your radiator over a PRC unit?
Justin@EntropyRad
03-03-2015, 08:17 AM
I can't speak to the PRC piece, and I think our stuff is top-notch for the money. We back up our stuff with a lifetime warranty, and do our best to provide the best service we can!
We are enthusiasts too, and understand how things go on builds.
I am biased to our product naturally, but have had experience with a few other brands out there. Some are great, some are good, and some are less than ideal. For the money, our products are hard to beat
Centralia69Camaro
03-03-2015, 10:12 AM
I might be currently having a problem with Entropy. A few weeks ago i ordered a radiator for my 69 Camaro w/572ci, from Justin and got free shipping for being a member here, I was told it would ship out right away but with the weather it didnt ship out for a few days, no problem.
Then i get the radiator and find out it is not the one i ordered. I called up to let them know they shipped the wrong one and was told they upgraded me for free. Wow sounds good. Except the upper hose is on the passenger side instead of the drivers side. Again, i can work with that but i had called them again to say hey im not putting it in for a couple of wseeks is it gonna be a problem if it turns out not to work for me to return it after so long. Frank said it would be fine. Now just a few days after that conversation i realized the the tranny lines are also on the wrong side ( i feel stupid for not seeing it before) Well i dont want to reroute my tranny lines too so i just decided to return this one and get the one i ordered. Thanks for the upgrade but no thanks.
Now im told i have to pay the shipping back. Doesnt seem fair to me.
I have a call into them and well see if they do the right thing. Or what i think the right thing is.
Justin@EntropyRad
03-03-2015, 12:28 PM
Tom,
We are still working on this..As you said, things happen..and we are doing our best to make things right
Centralia69Camaro
03-03-2015, 12:42 PM
Im sure it will all work out in the end. When it does i will be the first to say so.
SparkyRnD
03-12-2015, 06:38 PM
Let me know if you need a bolt-in unit for your Camaro, we make them by hand here in the USA and we're a forum sponsor (ask for discount when ordering)
Justin@EntropyRad
03-16-2015, 05:05 AM
It's all sorted out!
69LSX
06-12-2015, 05:09 PM
Justin, I sent you a PM and e-mail concerning my LSX-370 having trans fluid leaking into the radiator. Waiting to see if you will stand by your lifetime warranty and make things right ASAP. Car has never been driven yet. Only started and run to check all of the systems. Not too happy.
- Sammy
Justin@EntropyRad
06-15-2015, 12:20 PM
Apologies for the leaking you are having. This is a VERY rare occurrence, and I'm working with the higher ups on getting this sorted out for you Sammy. I talked to your builder, and got the address for the replacement to go out asap.
69LSX
06-15-2015, 12:30 PM
Thanks Justin. Sent an e-mail to you & Tony about added out of pocket expenses I am facing that should fall back on Entropy since unit was shipped defective. Hopefully you guys will make things right. Let me know. - Sammy
Justin@EntropyRad
06-16-2015, 11:58 AM
Responded in kind. I know your replacement shipped today
69LSX
06-16-2015, 02:00 PM
FYI
Justin & Tony of Entropy are working with me to get this right. A replacement unit is supposed to be on the way. I just want to keep this open so everyone knows Entropy is standing behind their product and keeping in constant communication with me throughout the process.
Thanks Justin.
Sammy
