View Full Version : And now for something different...
wallaka
03-11-2011, 07:46 AM
Not gonna say "not your average Pro-Touring car" or anything like that.
New car, '68 Mercury Monterey. 4000 lbs of comfortable, highway-eating fury. Specs: One-year only 390 "Premium gas" high-compression 2V. C6 auto, Ford 9-inch diff with 2.75 gears. Disc brakes. It'll boil at least one tire at will, 400 ft/lbs of torque will do that for you. Horsepower is down from the 4V cars, still a respectable 285. When I went to pick it up, I rented a Grand Marquis to try to get used to the bulk...not even close. This car runs stronger than the 4.6, too. Ride is very similar, for now, except more posh and floaty. My grandpa had one of these while I was growing up, and I thought it was the coolest thing ever, so when I saw this on craigslist, I jumped on it.
https://static1.pt-content.com/images/pt/2011/03/tZlpfs-1.jpg (http://i.imgur.com/tZlpf.jpg)
Next to older, midget brother:
https://static1.pt-content.com/images/pt/2011/03/LQ8mfs-1.jpg (http://i.imgur.com/LQ8mf.jpg)
Got rid of the wire wheel covers, they suck
https://static1.pt-content.com/images/pt/2011/03/xUoums-1.jpg (http://i.imgur.com/xUoum.jpg)
Sense of scale--they're all pulled up to the sidewalk
https://static1.pt-content.com/images/pt/2011/03/dFjems-1.jpg (http://i.imgur.com/dFjem.jpg)
Interior's in very good shape. It's not the poshest interior they had; bench seat, rolly-up windows. It does have seatbelts and a tilt steering wheel, good enough for me. There will be a reckoning one day with the climate control. One of the vacuum motors works, the other five will need to be replaced. Right now everything is ziptied into heater mode.
https://static1.pt-content.com/images/pt/2011/03/83f9fs-1.jpg (http://i.imgur.com/83f9f.jpg)
https://static1.pt-content.com/images/pt/2011/03/Sjue9s-1.jpg (http://i.imgur.com/Sjue9.jpg)
https://static1.pt-content.com/images/pt/2011/03/Ulzfgs-1.jpg (http://i.imgur.com/Ulzfg.jpg)
https://static1.pt-content.com/images/pt/2011/03/MzA4Qs-1.jpg (http://i.imgur.com/MzA4Q.jpg)
This car is pretty straight. Only rust is in the trunk area, pretty typical for something that has a rear window sealing area of approximately 200 yards. Luckily, there's new front and rear window seals in it, plus new trunk weatherstripping. The PO was an old guy with a passion for old Fords and Mercurys, and he did some maintenance. The car is mechanically sound, just has the typical FE leaking valve covers. I've already replaced the distributor vacuum advance.
First thing: Fix the speedometer. The cable is cut and the needle is broken off. The PO helpfully included a new speedo cable. While I'm at it, tunes. The AM-only radio is ****e, there's only so much Glenn Beck I can take before I go on a rampage.
So...dash off
https://static1.pt-content.com/images/pt/2011/03/UDDCMs-1.jpg (http://i.imgur.com/UDDCM.jpg)
https://static1.pt-content.com/images/pt/2011/03/N8ZSqs-1.jpg (http://i.imgur.com/N8ZSq.jpg)
I swear this is the original speaker.
https://static1.pt-content.com/images/pt/2011/03/iTvvYs-1.jpg (http://i.imgur.com/iTvvY.jpg)
Goodbye.
https://static1.pt-content.com/images/pt/2011/03/osaXns-1.jpg (http://i.imgur.com/osaXn.jpg)
Hold the mounting sleeve to the original radio mount, spray paint around and you know where to cut.
https://static1.pt-content.com/images/pt/2011/03/pI5HGs-1.jpg (http://i.imgur.com/pI5HG.jpg)
Trala!
https://static1.pt-content.com/images/pt/2011/03/Q7mZGs-1.jpg (http://i.imgur.com/Q7mZG.jpg)
Also:
https://static1.pt-content.com/images/pt/2011/03/CF8ARs-1.jpg (http://i.imgur.com/CF8AR.jpg)
Speedometer time:
This will not do.
https://static1.pt-content.com/images/pt/2011/03/q8txMs-1.jpg (http://i.imgur.com/q8txM.jpg)
interesting little clips hold the cluster together.
https://static1.pt-content.com/images/pt/2011/03/CssSHs-1.jpg (http://i.imgur.com/CssSH.jpg)
Epoxy
https://static1.pt-content.com/images/pt/2011/03/iKlnFs-1.jpg (http://i.imgur.com/iKlnF.jpg)
Result-success!
https://static1.pt-content.com/images/pt/2011/03/r2I4ds-1.jpg (http://i.imgur.com/r2I4d.jpg)
https://static1.pt-content.com/images/pt/2011/03/0NoU5s-1.jpg (http://i.imgur.com/0NoU5.jpg)
Next:
What could all this be for?
https://static1.pt-content.com/images/pt/2011/03/uicjws-1.jpg (http://i.imgur.com/uicjw.jpg)
I have gotten a lot of inspiration from this site, time to give back.
wallaka
03-11-2011, 07:51 AM
Hmm, a few problems here
https://static1.pt-content.com/images/pt/2011/03/glTRus-1.jpg
(http://i.imgur.com/glTRu.jpg)
https://static1.pt-content.com/images/pt/2011/03/4JzNJs-1.jpg
(http://i.imgur.com/4JzNJ.jpg)
Got a solution:
https://static1.pt-content.com/images/pt/2011/03/c3VjDs-1.jpg
(http://i.imgur.com/c3VjD.jpg)
Bilstein, valved by RCD to hopefully control these:
https://static1.pt-content.com/images/pt/2011/03/QKz82s-1.jpg
(http://i.imgur.com/QKz82.jpg)
Moog springs for an '02 Crown Vic police interceptor. Gotta see what the drop, if any, is. Compressed height is supposed to be very similar.
These shocks are quality
https://static1.pt-content.com/images/pt/2011/03/omDXIs-1.jpg
(http://i.imgur.com/omDXI.jpg)
Not nearly as bad as I thought it would be, getting replaced anyway
https://static1.pt-content.com/images/pt/2011/03/9cLPYs-1.jpg
(http://i.imgur.com/9cLPY.jpg)
Need some carcino-mallows?
https://static1.pt-content.com/images/pt/2011/03/pKtEOs-1.jpg
(http://i.imgur.com/pKtEO.jpg)
mmmmmm.....
https://static1.pt-content.com/images/pt/2011/03/j0nKRs-1.jpg
(http://i.imgur.com/j0nKR.jpg)
Energy Suspension poly going in...
https://static1.pt-content.com/images/pt/2011/03/5ESOus-1.jpg
(http://i.imgur.com/5ESOu.jpg)
Had to slot the shocks to fit:
https://static1.pt-content.com/images/pt/2011/03/0czeGs-1.jpg
(http://i.imgur.com/0czeG.jpg)
New Moog ball joints, new brake hoses (both were originals)
https://static1.pt-content.com/images/pt/2011/03/EqNuCs-1.jpg
(http://i.imgur.com/EqNuC.jpg)
New Addco anti-swaybar for a Thunderbird. Beefy.
https://static1.pt-content.com/images/pt/2011/03/Ik9lys-1.jpg
(http://i.imgur.com/Ik9ly.jpg)
Detail: 1 1/8" vs 3/4" stock bar
https://static1.pt-content.com/images/pt/2011/03/6rcBgs-1.jpg
(http://i.imgur.com/6rcBg.jpg)
This car is gonna drive like Mercury was owned by Bavarians.
wallaka
03-11-2011, 07:53 AM
The pinnacle of 1972 street suspension tech. Hi-Jackers!
https://static1.pt-content.com/images/pt/2011/03/HMb6ks-1.jpg
(http://i.imgur.com/HMb6k.jpg)
On to the rear springs: Moog cargo controls, made for a '68 Galaxie wagon. Spring rate is, again, roughly doubled from stock, though these are progressive springs (which I didn't particularly want, but it's all that is available).
https://static1.pt-content.com/images/pt/2011/03/O4Oq3s-1.jpg
(http://i.imgur.com/O4Oq3.jpg)
It's weird but even though all the springs I got are supposed to have the same compressed height as the stock parts, the car sits lower. I don't know if that's supposed to be the stock ride height or not. The PO had those Hi-jackers aired up and the coil spacers in the front, it could explain it. I put it down to 40-year old sagging springs, but it does make me wonder.
I wanted the car lower anyway.
I have to go to the hardware store tomorrow. I've never seen a shock shaft with fine threads on it, but these do. Of course, they packed coarse thread nylocks with them. I should be done with the suspension tomorrow, all I have to do is mount the rear shocks and bleed the brakes.
wallaka
03-11-2011, 07:55 AM
Got the nuts, hurr.
Replaced the last brake hose, went ahead and flushed all the brake fluid out.
This is how you know you have original brake hoses on a late 60's Ford. Note that the brass fitting was actually cast into the bracket.
https://static1.pt-content.com/images/pt/2011/03/IquoNs-1.jpg
(http://i.imgur.com/IquoN.jpg)
This is what it looks like when you fit the new hose to the bracket:
https://static1.pt-content.com/images/pt/2011/03/X7O3Fs-1.jpg
(http://i.imgur.com/X7O3F.jpg)
I was alone and needed to bleed my brakes, this is the easiest way to do it. Never seen any need for a Mityvac. Your master cylinder can push a lot more pressure than that thing can pull. You need a little brake fluid in the jar to start so you don't suck air back up, but you can go right ahead and flush the brake circuit while you're at it. FYI, your brake fluid should not be that color.
https://static1.pt-content.com/images/pt/2011/03/P2ZXMs-1.jpg
(http://i.imgur.com/P2ZXM.jpg)
That was the last step. Parked hard:
https://static1.pt-content.com/images/pt/2011/03/ZzKcws-1.jpg
(http://i.imgur.com/ZzKcw.jpg)
wallaka
03-11-2011, 07:58 AM
The 2” single exhaust was strangling the big block. Went to Autozone...
https://static1.pt-content.com/images/pt/2011/03/73zTJs-1.jpg
(http://i.imgur.com/73zTJ.jpg)
Burned through a couple times before I got the welder adjusted right
https://static1.pt-content.com/images/pt/2011/03/BWa9ds-1.jpg
(http://i.imgur.com/BWa9d.jpg)
Good penetration
(http://i.imgur.com/Zq8kz.jpg)
This reducer should just slip into the existing pipe and I'll clamp it. Easily removable. I would've gotten one that went outside, but they didn't have any. Whatever.
https://static1.pt-content.com/images/pt/2011/03/TCfyHs-1.jpg
(http://i.imgur.com/TCfyH.jpg)
https://static1.pt-content.com/images/pt/2011/03/gSG3ys-1.jpg
(http://i.imgur.com/gSG3y.jpg)
$60 for dual exhaust, not bad. These are perforated core, not louvered, so they are as free-flowing as mufflers get. Yeah, the turndowns are crush bent but I doubt it'll matter. Turns out I got the wrong reducers too, so had to fill in a bit. Gave me practice lapping my welds, not a loss.
wallaka
03-11-2011, 08:09 AM
I got an idea.
https://static1.pt-content.com/images/pt/2011/03/e7tLcs-1.jpg (http://i.imgur.com/e7tLc.jpg)
https://static1.pt-content.com/images/pt/2011/03/r8oArs-1.jpg (http://i.imgur.com/r8oAr.jpg)
https://static1.pt-content.com/images/pt/2011/03/uVepks-1.jpg (http://i.imgur.com/uVepk.jpg)
https://static1.pt-content.com/images/pt/2011/03/HqvuQs-1.jpg (http://i.imgur.com/HqvuQ.jpg)
I think they'll do for now. Can't beat the price, since I already own them. This should stop the terrible sidewall-rolling issues I'm having.
These are VMR V710s, sized for a BMW M3 (one of my other cars):
Rear: 19x9.5 ET+22, (6.11” BS) 285/30-19
Front: 19x8.5 ET+35, (6.12” BS) 245/35-19
Both have a 1” spacer/bolt adapter and fit perfectly. Zero rubbing on the front, and a slight fender roll in the rear.
I'm not going to leave these on forever, but it'll be good for now. I might go to a bigger sidewall on front, it doesn’t look quite right but it’s close.
The car handles like a BMW 545 with the Sport Package now. It's not quite to M5 specs :)
wallaka
03-11-2011, 08:12 AM
Time to install more parts. The easy part is done:
https://static1.pt-content.com/images/pt/2011/03/n9G1ps-1.jpg
(http://i.imgur.com/n9G1p.jpg)
Et Voila!
https://static1.pt-content.com/images/pt/2011/03/DLgC4s-1.jpg
(http://i.imgur.com/DLgC4.jpg)
Needed a break after that one, glad I've been going to the gym.
110 lbs. of cast iron and spite:
https://static1.pt-content.com/images/pt/2011/03/ACjgls-1.jpg
(http://i.imgur.com/ACjgl.jpg)
[/quote]
Progress!
https://static1.pt-content.com/images/pt/2011/03/kTctns-1.jpg
(http://i.imgur.com/kTctn.jpg)
I need a carb spacer, kickdown adapter, and radiator hose fittings now...it never ends.
Next money is being spent on junkyard rear disc conversion. Should be able to pull everything I need for $100 or so, not counting a master cylinder. A Crown Vic will again be the donor.
Finally!
https://static1.pt-content.com/images/pt/2011/03/S4Efts-1.jpg
(http://i.imgur.com/S4Eft.jpg)
Now I need an air cleaner that doesn't hit the hood. And a tuning kit, it'll run, but it's rich enough that it throws black smoke everywhere and makes my eyes water. I have a wideband O2 that I need to install, no guessing for me.
Bryce
03-11-2011, 08:20 AM
This is super cool!
LeighP
03-11-2011, 08:32 AM
Very cool car...love the body lines.
Toadman
03-11-2011, 09:48 AM
Kewl!! :smoke: That thing begs for a good nickname!
monteboy84
03-11-2011, 10:20 AM
Ha that thing is looooooooooooooooooooong, I like it.
-matt
6'9"Witha69
03-11-2011, 10:38 AM
Have you upgraded the main mast yet? :poke:
Looks like good progress. I have a FE390 in my '62 F-100. Good engines. Terrible intake/valvetrain design, but good engines.
Nessumsar
03-11-2011, 10:47 AM
One of the coolest builds right now! This things should be a hoot when its done.
Subscribed!
wallaka
03-11-2011, 11:14 AM
The difference from stock is night and day. There's no body roll. No brake dive or "planing off" on acceleration. It does this and isn't harsh either. I had visions of going over a set of railroad tracks and all the trim falling off. That said, it is LOW. The exhaust turndowns scrape over speed bumps. There's about 1/4" frame clearance over my jack. I had contemplated lowering springs, and I'm glad I didn't get them.
I set it up to understeer a bit...I couldn't imagine all 19 feet sideways. I think that it doesn't have enough power yet to get me into trouble anyway, but planning for the future. I'm planning on a mild turbo installation, only 500 hp or so. It shouldn't take much to get there, and I want it quick-spooling. I just haven't decided between twins or a big single.
Mainmast upgrade next month, it takes a while to find the right tree.
Bullockracing
03-11-2011, 04:46 PM
Awesome ride! I love anything different, and this certainly qualifies!!!
The Stickman
03-11-2011, 06:15 PM
Great project. Good to see I am not the only heavyweight here, lol.
dusterbd13
03-11-2011, 08:39 PM
i love boats.
one day i will build a NASCAR clone 63 galaxie (only done ti PT specs so i can open track it)
ill be watching this one closely.
Michael
cobragt
03-11-2011, 09:28 PM
Very cool!
asifnyc
03-12-2011, 08:56 PM
now that's cool!
wallaka
03-16-2011, 06:50 AM
No huge updates, except tuning. Got the bung welded in for the wideband and the tuning kit for the carb. Looks like it was set up for drag racing; the metering rods were bent 90* at the tip and did zero metering. This means no transition circuits, just main jet action at all times. Right off idle A/F ratios shot under 10 and stayed there. I swapped to smaller mains and richer metering rods. It's not perfect yet, but getting there. Cruise A/F ratios are 14.2 or so at 70 mph, 15 at 50 but lean out a lot more at lower RPM cruise. Not sure how to solve this, maybe a larger main but leaner metering rods. I only played around with it for an hour or so. WOT A/F is decent, 11-12 at least until the secondaries come all the way in, the numbers continually richen up as RPMs rise. Maybe I should get a tach so I can see exactly where this happens.
Also got a Grant 960 steering wheel, classic walnut-rivited with brushed aluminum spokes. Classy.
craigs73
03-16-2011, 06:56 AM
cool that thing should be named project land yact lol things big enough to have its own zip code im just joking. glad to hear it handles alot better than it did great work
rfalker1
03-16-2011, 06:58 AM
awesome build and a oscar for the best word every used seriously
Trala!
wallaka
03-18-2011, 08:40 AM
4544445443
Got the valve covers off of eBay, $30. Gonna strip 'em and paint 'em, haven't decided whether Marauder orange like they are now, or regular Mercury gold. I'm not a fan of corporate blue.
cobragt
03-18-2011, 10:17 AM
4544445443
Part of the fun is doing your own thing.
67chevILL
03-18-2011, 10:18 AM
just read threw the thread. looks like a very cool and diffrent project.
1969CamaroRS
03-18-2011, 10:27 AM
x2, definitely keep the pics coming. Need some more shots of the car!
wallaka
03-18-2011, 02:19 PM
I have one of those G-meter apps for my iPhone, it's pretty accurate. Was when I tested my M3, anyway, it calculated 335 horsepower and the car is rated at 333.
Ran the Mercury down a backroad this afternoon after I set the timing and dwell. Got a 9.2 second 0-60, calculated 250 wheel horsepower with a 4000 lb estimated car weight. It extrapolated a 16.7 second quarter mile at 100 mph, using my 60' of 3.0.
That would be 295 flywheel horsepower assuming 18% driveline loss. The gross rating for the 4V high-compression 390 was 320, so it's pretty plausible with the work I've done. Pretty happy about that!
wallaka
03-19-2011, 04:42 PM
Ready for primer
45450
This is the A-pillar trim, apparently had a leaky windshield at one point.
Only had enough time to strip one of them. The other side gets the flaky stuff knocked off, then Metal Ready and POR-15 because I can't reach all of it.
45451
I have a can of SEM Landau Black ready to go on, a nice semi-gloss black that matches most any interior finish. I also have a can of Texture Coat to redo the camera finish on the glove box.
MonzaRacer
06-05-2011, 11:15 PM
No what it means is that the last person to work on it didnt know how to install the metering rods. As long as they are not deformed they can be straightened with small vise grips and saved My old 600 Competition AFB was in similar shape from old 283 a buddy bought for his race car, but instead of fixing and cleaning it up he wound up using an electronic Qjet without the computer. talk about quadra bog!
grenade inspector
06-06-2011, 05:38 PM
thats a really nice car you have, subscribed!
64impala
06-07-2011, 01:38 PM
Its soooooo nice to see another unique pro-touring build. Im building a 64 impala myself. Good luck
Nessumsar
06-07-2011, 02:55 PM
With this being brought back up to the front I must ask, any new updates?
wallaka
06-10-2011, 11:59 AM
Updates: well, had a bit of an electrical problem that took a while to sort out. I finally traced it down to the horn wiring somehow shorted out. Now the horn is run through the accessory post on the headlight switch, so it made the headlight switch melty (apparently the accessory wire isn't run through the circuit breaker), and somehow burned up the starter wire from the ignition switch to the bulkhead connector. So I have a new headlight and ignition switch and new wiring--horn still doesn't work but the car runs battery charges, and the headlights work, finally. Had the dash out for a month troubleshooting off and on when I wasn't too mad to deal with it. The car still runs fine enginewise. I'm getting ready to pull the front accessories off to fix the timing cover oil leak, but haven't yet. The painted trim is back in the interior. Oh, and I got another head unit. It has two knobs and looks more better. I need to upload pics.
Switched the 19's out for the stock M3 18's, they also fit well. There was a tad bit of control arm contact but I solved that. The 18's definitely fit the look of the car better, I'll get some installed pics later. Got 255/40 and 225/45, 9" and 8" respectively. Here's a pic of the wheels:
https://static1.pt-content.com/images/pt/2011/06/KsV4r-1.jpg
I put the VMR brushed metal centercaps on though, the BMW ones just wouldn't work. Other than that, no real progress. I'm going to go and fab more exhaust, but it's been too dang hot to do much in the shop lately. It's been upper 90's/low 100's for like 3 weeks now.
wallaka
06-10-2011, 12:01 PM
They're crimped shut. Not salvageable, but I have extras anyway.
wallaka
06-12-2011, 07:30 PM
https://static1.pt-content.com/images/pt/2011/06/kAMtpm-1.jpg (http://imgur.com/kAMtp)
https://static1.pt-content.com/images/pt/2011/06/uZ3Zym-1.jpg (http://imgur.com/uZ3Zy)
https://static1.pt-content.com/images/pt/2011/06/XafpYm-1.jpg (http://imgur.com/XafpY)
I assure you the car is still white. Stupid iphone pictures.
