View Full Version : 20x13's on a 69 camaro???
adriana
03-07-2011, 02:31 AM
i am building a 69 camaro and i want to know if anyone can tell me for sure if i can use a 20x13 on the rear because most of the time i see 12's. the car has air ride and wilwood disc brakes and of course it has been mini tubbed with detroit speed tubs. i also want to know the widest wheel i can run on the front without clearance issues if i run a 19. there are no mods on the front other than tubular control arms on the stock frame so i assume it is basicly as it was stock. i'm not sure what other info would be helpful so let me know. thanks for the help
ProdigyCustoms
03-07-2011, 08:35 AM
A 13" wheel will make the section width about 6/10ths wider then a 12" wheel which is just enough to push it over the edge of fitting the standard mini tub. A 12" wheels squeezes the tire just enough to let it fit.
adriana
03-07-2011, 09:16 AM
thank you frank, will i be safe with a 19x8.5 on front with no mods? if not what should i run?
ProdigyCustoms
03-07-2011, 09:20 AM
There is a lot to all this especially as it relates to aspect ratio. Probably best to call me
2blownstangs
03-16-2011, 08:06 PM
any pics of the project? Sounds bad ass
Will
adriana
03-16-2011, 09:30 PM
i had a few and my cpu was struck by lightning so i lost everything. i will try to get some new ones when it gets back to the paint shop because i would like to get some suggestions on interior ideas anyway. im hoping to have it complete by mid-summer because it's only been torn apart since 2005. ha ha i'm sure somebody on the site can relate with me. thanks for the interest i'll try to keep you posted.
