View Full Version : L92 PCM help...... which harness/controller?
Samckitt
03-05-2011, 06:36 AM
So I have a 6.2L L92 heading my way soon and I am teetering on which harness/controller to go with. One option is have a new harness made & use the regular L92 PCM or 2010 Camaro PCM (evidently it will control the VVT). Doing this requires a dyno tune, but uses all factory GM stuff, so I could go anywhere to find out what is wrong if the check engine light comes on. New harness is near $1000, dyno tune around $500, cam & springs another $400 or so.
The other option I am debating is a MAST Motorsports harness/controller package. It is a complete stand alone harness, it has the connections for the ignition switch, Neutral / clutch switch, all fuses & relays in one little mountable box. But it doesn't use the mass air sensor & if the check engine light comes on I have to use their software to pull the codes. Controller/harness package is over $2200, software to pull codes is another $300, & debating going with their cam/springs package that they claim will make up to 550 hp at the flywheel. And their controller is pre tuned for it.
scherp69
03-05-2011, 03:36 PM
I'm planning on buying the Mast one this spring. Everything I've read and heard about theirs, it's very easy to tune yourself with the software. Apparently their software allows you to tune things that normal tuning programs won't allow you to. I don't remember what they were, but remember reading that. I also like the idea that they come pretuned to their cams and may need a little tweaking if you have any extras. It's also supposed to be literally plug and play. Plug everything in, run power to it and your set. Mast gets my vote.
Samckitt
03-06-2011, 05:57 AM
47 views and only 3 votes & 1 reply?
Samckitt
03-06-2011, 10:09 AM
If voting "OTHER", what is other?
tommycomfort
03-06-2011, 01:46 PM
Well, Mast got my vote, but you already knew that. If all goes well I will have mine fired up and back on the road in a few weeks and I will let you know what I think.
Tom
Samckitt
03-06-2011, 01:56 PM
I should be in Noblesville next week. Maybe if I have time I will come down.
tommycomfort
03-06-2011, 04:47 PM
That would be great! I live in Mooresville (just southwest of Indy) but our garage/shop is in Greenwood (just south of Indy). We love visitors and all kinds of cool parts are showing up early next week! (headers, clutch and flywheel stuff and Vintage Air front runner system)
Tom
317 502 7460
Samckitt
03-07-2011, 06:49 AM
Tom
317 502 7460
That's cool, I have friends in Greenwood that I was going to visit too. Getting there through the week or during working hours though may be the tough part. What part of Greenwood you in? I lived there for a little while too, west of 31, south of Main.
tommycomfort
03-07-2011, 07:03 AM
We're right off of Smith Valley rd. between SR135 and 37 not too far at all from where you used to be.
68Formula
03-07-2011, 07:20 AM
Looks like the MAST unit allows wideband control (closed loop even under high load/WOT). The other nice thing is they've already done the homework on the tuning their camshafts with VVT. It would take days to do this on a dyno to optimize camshaft position for VE and spark timing for MBT at part loads as well as WOT.
Samckitt
03-07-2011, 08:26 AM
Gotta think where that is, I lived south of Smith Valley, West of 31. Can't remember the housing edition, is on Ellington Circle. So you are West of there 5-10 miles or so.
The WidowMaker
03-07-2011, 09:37 AM
im still debating on my engine choice, but im leaning towards the mast harness as well. i still have a bunch of reading to do to figure out all the wiring, but it sounds like the mast harness will take care of some of the stuff that the gmpp harness wont (fans, ac, fuel pump, dash etc)
Samckitt
03-07-2011, 10:30 AM
Tim,
Do you have MAST's installation instructions? I have it & it tells alot.
The WidowMaker
03-07-2011, 12:03 PM
scot, i just downloaded them and havent read them yet. looks like a lot of answers though.
Samckitt
03-07-2011, 12:07 PM
Yep, has a lot of info in it I hadn't seen anywhere else. But also opened some concerns/questions I didn't think of because I "assumed" too much.
Like:
MAST Controller
Does not have a MAF, it uses Speed Density.
Does not have a speed sensor
So also, will not control cruise control.
Has it's own starter circuit, so remove yours & use the connectors they have for the ignition switch & for the Neutral/clutch switch.
AC harness is an add on circuit.
The WidowMaker
03-07-2011, 12:55 PM
i believe they started adding all of the harnesses with their kits. you might want to call and confirm, but i had asked about the fans and fuel pump and while they used to be add ons, they are now included.
Samckitt
03-07-2011, 12:58 PM
Yes Fans & fuel pump relays & fuses are in it.
andrewb70
03-07-2011, 04:13 PM
Are you in love with the VVT?
68Formula
03-07-2011, 04:51 PM
He will be :twothumbs:
http://www.ls1tech.com/forums/generation-iv-internal-engine/714881-gm-gen-iv-vvt-performance-gains.html
andrewb70
03-07-2011, 05:05 PM
That post is a little misleading. They conducted the testing of the stationary cam at the two extreme positions, one for peak torque and one for peak HP. What I would like to see is a cam position that is a compromise between the two extremes. I bet the area under the curve difference would not be as dramatic.
I am not saying that the technology is not neat or useful. All I am saying is that it may not be as dramatic as these Mast results indicate. VVT was designed for engines that have less than ideal cam profiles for performance. The VVT also adds another component that can potentially fail.
daytonayellaz
03-10-2011, 06:44 AM
You know my thoughts on this as well Scot.... I love the new Mast controller package. I like that they took the the VVT technology and developed there own cams for VVT with extensive R&D. VVT has been around for several years now and as far as Im aware, no added problems due to the technology?? I really dont think Mast would have spent all the time and money on the R&D with VVT technology if it wasnt worth it?? I personally like it, but if one didnt like it.....its very easy to eliminate. :twothumbs
Samckitt
03-10-2011, 09:33 AM
Yeah I know your thoughts, which is probably the way I am going. Just wondering what others thought.
