View Full Version : wil corvette front drive asc work on a first gen ls swap
s10pro
02-24-2011, 07:20 AM
i am gathering parts to began my swap, gm crate ls6 , also got all vette stuff alt and bracket and power steering ,will this work, also i am running stock steering not rack style, what pan would be best for me , i dont have plates or headers or any thing yet , any info would be great, thanks
hifi875
02-24-2011, 07:42 AM
i run it on mine. with brp setup and i notched the frame
130fe
02-24-2011, 09:04 AM
As long as you dont try and use the vette AC, you will fine with most plates (if you are going to be using a stock subframe). Be sure to match headers and plates from the same company. There is alot of information here and a great sticky over at http://www.ls1tech.com/forums/conversions-hybrids/472609-lsx-into-67-69-camaro-basics.html on the swap.
69X22
02-25-2011, 12:08 AM
I'm running a Art Morrison subframe with the vette brackets, the only thing I had to do is modify the Vintage Air brackets to bring the compressor closer to the engine, this left about 1/4" between the frame and compressor. I did this so I could run a Pro Charger.
